Coolant in Oil HELP!!!!!!!!!!
Old Jan 21, 2009 | 04:36 PM
bmlawson's Avatar
bmlawson
I have a 04 FX4 with the 5.4 with 118863 miles on it as of today. I went out today in the cold to change my oil. I first noticed my coolant being al little low yesterday. It is about 2in below the cold fill line now. So I go to drain my oil and coolant starts coming out. WTF??? I am thinking that it may be leaking from the intake? or Head gaskets? Any advice would be very much appreciated because this is my only vehicle and I am unemployed, plus have a kid on the way. Thanks for looking
Old Jan 21, 2009 | 06:49 PM
fitz888's Avatar
fitz888
sounds like a bad head gasket to me
Old Jan 21, 2009 | 07:08 PM
Catmonkey's Avatar
Catmonkey
I can only think of two possibilities, a blown head gasket or a cracked block. I'd run a compression test on it. You could also pressurize the cooling system with a testing kit and see if it won't hold pressure.
