360 bored
Old Jan 21, 2009 | 03:29 PM
bigfoot22's Avatar
bigfoot22
360 bored
What cubic Inches do you get if you take a stock 360 and have it bored .030 over?I've been told differant numbers and want to hear from someone that really knows.Thanks-Ken
Old Jan 21, 2009 | 04:55 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
4.08 (.30 over) bore and 3.50 stroke net you a 366 CI.
Old Jan 30, 2009 | 02:33 PM
Moto Mel's Avatar
Moto Mel
The easy formula for figuring CID is;
Bore times bore, times stroke, times .7854, times number of cylinders = CID
4 inch bore X 4 inch bore= 16 X 3.5 stroke = 56 X .7854 = 439824 X 8 cyls =351.859 cid.
I hope this helps you and others that need to use this formula. It took me years to remember it as I am mathmatically challenged. I also suffer from old timers disease AKA CRS.
Old Feb 1, 2009 | 11:02 AM
court1100f's Avatar
court1100f
Hey man just some food for thought but if you wanted to replace the entire rotating assembly you could getta Mega FE E.G. at 040 over with a 4.25" Stroke you'd have a (447.75)448Cid at 050 a (449.41)450Cid and at 060 over a (451.07)451Cid
P.S. that rotating assembly in question that I used for those end displacements would run about $1,389.00-$1,699.00 depending on which kit you got Either kit would have Rods,Crank,Pistons,Bearings,Piston rings,and Wrist pins
Thats personally what I intend to do when I rebuild my 360Cid I'll end up with a 448 or 450 cause I want atleast .010 to clean up the cylinders for a rebuild
Jeff Beerbower
Aug 16, 2012 08:04 AM
Big block 68
Jul 31, 2012 08:01 PM
dino360
Dec 14, 2004 07:50 PM
66beater
Sep 21, 2004 11:31 AM
71and72F100s
13
Jan 5, 2003 03:20 AM
