Help on installing Tach
Old Jan 21, 2009 | 10:57 AM
iamhoss89's Avatar
iamhoss89
Question Help on installing Tach
Hi, I have a 1993 ford f-150, 4X4. it has the 5.0L. I have been having some trouble installing an aftermarket tach. Since there is no negative side to the coil what should i do?
Old Jan 21, 2009 | 11:05 AM
f250ssd's Avatar
f250ssd
Hook it up to the Tan/Yellow wire coming off the coil.
Old Jan 21, 2009 | 11:08 AM
MisterDave2's Avatar
MisterDave2
Yes, and if you put a small electrical push clip on it, it will slide right behind the wire tab on the coil and stay put perfectly.
Old Jan 21, 2009 | 12:56 PM
iamhoss89's Avatar
iamhoss89
Ill give it a try, thanks!!
