engine kills when shifting
Old Jan 20, 2009 | 10:24 PM
tbirdrief's Avatar
tbirdrief
Hello,
When I shift the engine kills. When I let out the clutch it starts right up.
I thought that my fuel was bad changed filter, but still happens.
Any ideas.
Thank you,
'89 F350 4X4 7.3
Old Jan 20, 2009 | 11:43 PM
pjwoolw's Avatar
pjwoolw
At any speed?
Old Jan 21, 2009 | 07:57 AM
PLC7.3's Avatar
PLC7.3
Does it do it when the clutch is pushed in anytime........ stops, cornering etc. If so then there is a TSB for that problem. Relates to dirt/crud/ slime in the IP.
If you would like the TSB....
click on my name and PM me your email addy.... Use subject: TSB IP
Old Jan 21, 2009 | 04:55 PM
tbirdrief's Avatar
tbirdrief
[QUOTE=PLC7.3;7036991]Does it do it when the clutch is pushed in anytime........ stops, cornering etc. If so then there is a TSB for that problem. Relates to dirt/crud/ slime in the IP.
Hi,
I stalls at mostly lower speeds (stop sign/light) and when it is not quit up to peek temp. When it is up to temp and I have been workin her I haven't noticed it.
Thanks
Old Jan 21, 2009 | 06:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
A good strong dose of Diesel Kleen may fix your stalling issue.
Old Jan 21, 2009 | 10:10 PM
tbirdrief's Avatar
tbirdrief
Thanks I'll try that first.
Old Jan 21, 2009 | 10:33 PM
David85's Avatar
David85
+1 on that
