Sponsored by: Real Truck
Thrust washers loose
Old Jan 20, 2009 | 08:00 PM
Phishnvdub's Avatar
Phishnvdub
Two weekends ago I put Warn Manual locking hubs on my truck. I was just reading another post on someone replacing their hub assembly. This reminded me to ask about my thrust washers behind the hub locking assembly. Mine were loose behind the C-clip. I could spin them around the axle shaft. Should they do this or be tight between the hub assembly and C-clip? This is probably a stupid question but the washers being like that did not seem right.
Old Jan 21, 2009 | 12:14 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I honestly don't remember, anyone else got a clue?
Old Jan 21, 2009 | 05:26 PM
FireMe's Avatar
FireMe
A little play is normal, about 1/16" or less. I don't recall a spec in the manual, but any more and you'll want to replace all of the washers, both metal and plastic. Too much end play will allow the seals to wear and dirt/water will enter the needle bearing in the hub.
Jay
Old Jan 21, 2009 | 06:21 PM
Phishnvdub's Avatar
Phishnvdub
I'll be doing some work on the truck this weekend. I'll check to see exactly how much play I have and post back. Thanks
rickmun
Mar 15, 2017 01:28 AM
DoeyDooper
1983 - 2012 Ranger & B-Series
Feb 14, 2017 10:30 PM
Mikeno11
Offroad & 4x4
Oct 18, 2016 03:40 PM
olderf150
Feb 26, 2016 10:04 AM
Biggone
Jan 5, 2012 01:45 PM
