i just finished changing my water pump in my 7.3. got it all finished and relized i used the old water pump gasket!!!!! Grrrrr!!! should this be ok long term??
What were you thinking Rus? lol This happens, if its not leaking you may get away with it like Dan said. I would wait till it leaks before changing it. You do know how to change it now.
everything went so well changing it!! 2.5 hours complete!! and then this happens! Grrrrr! like you said, at least i know how to change it know! hopfuly it will hold! i think it should be ok.
If the gasket looked "that good" that you mistakenly re-installed it, you should be OK. I replaced my W/P at 98k miles and the "new" gasket started seeping, at the top, and I had to replace it 50k miles later. Went ahead and put another new W/P on there for good measure. Gasket was only $5, but I didn't want to have a "do over'', later. It looked a little "iffy" around the weep hole.
As previous if not leaking drive on. We have all had our phopas,,, While doing the 4wd front hub replacement I put the backing plate on backwards and didn't catch it until I could not get the rotor on.,, then had to pull the bearing and axle back out to install it correctly. Drive on.
That is what happened to me... no leakes - so far. Biggest problem was standing on my short ladder to be able to reach over the front and that blessed hood latch jabbed me in the gut......
Bob
Yeah, I know I should have covered it with some padding... live and learn
Bob
Bob
Bob
My son gave me a Top Side Creeper. It is great for working under the hood of the Excursion 4wd. The truck is high and I have a bad back. I used this to do my water pump. Took 3 days and had no back issues. You might consider one.
