Fuse block
Old Jan 20, 2009 | 05:45 PM
29abone's Avatar
29abone
Fuse block
How do you remove the fuse terminals from a circa 1990 F-150 fuse block? I want to use the Ford fuse block to rewire my 56 F-100, and I do not want to splice the wires. If this won't work, can you suggest another fuse block?
Old Jan 20, 2009 | 07:10 PM
Franklin2's Avatar
Franklin2
I have never done it before, but I have heard guys adding electric windows taking the fuse block apart somehow.
Old Jan 20, 2009 | 07:38 PM
JD IN NJ's Avatar
JD IN NJ
On wire connecters the metal tong is v shaped you push the tong into the back of the case compressing the v and it snaps in place. To disconnect you use a small scewdriver and inside the case compress the v and pull the wire out . If your lucky fuss block will work the same.It may be better to add another fuse block to your 56
