Gas Guage
Old Jan 19, 2009 | 10:14 PM
Hank85713's Avatar
Hank85713
Gas Guage
04 Lariate 4x4, my sons truck. We bought new now we have a question. The fuel guage is slow to show level after filling up. Does anyone know if its a sender or is it a dash cluster issue. I guess it works once it shows the fuel level its jsut slow getting to full on the guage.
Thanks Hank
Old Jan 20, 2009 | 02:25 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
they sometimes do that
and sometimes they don't even register for a while. some guys report it being hours or days before the gas gauge updates
wish I could have something better to post besides "they do that"
Old Jan 20, 2009 | 06:08 AM
FX4Jim3's Avatar
FX4Jim3
Same here just started to do it. May be it,s the cold up here NE Ohio.
Old Jan 20, 2009 | 08:38 AM
Ryan50hrl's Avatar
Ryan50hrl
i think there may have been a tsb about this problem......check the link at the top of the page...
Old Jan 20, 2009 | 09:55 AM
Still Smoking's Avatar
Still Smoking
Ya I had the same problem. But mine has only did it twice. Once in like October and once like a month ago. Both at the same gas station. Got a mile down the road and was like wtf. Took it anywhere from 10 minutes to a hour. Really weird. I have been meaning to ask the same question. A buddy I worked with bought a 06 f150 and his was doing the same thing. He had to take it in to get scratches fixed they said they would when they bought it. I was hoping to hear what it was but he got laid off that day.
Old Jan 20, 2009 | 11:33 AM
f-150 on 22's's Avatar
f-150 on 22's
Try fueling up with the truck off.
Old Jan 20, 2009 | 12:53 PM
FX4Jim3's Avatar
FX4Jim3
Nope not on mine, always shut it off at fill up.
Old Jan 20, 2009 | 04:13 PM
jsoko's Avatar
jsoko
When I fill up my '06 with key off, and then top off, does'nt show full untill I drive about 2mi.
Old Jan 20, 2009 | 04:25 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
I have found if you dont turn it off or turn key to on when adding fuel it takes fore ever to go to full if you filled it
Old Jan 20, 2009 | 09:25 PM
Hank85713's Avatar
Hank85713
I looked throught the 04 & 05 TSBs didnt see anything on fuel guages.
Anyone else have any thoughts on this or know what was done to the truck for the guy who was laid off?
Old Jan 21, 2009 | 12:52 PM
jstnromero's Avatar
jstnromero
what type of fuel are you running? big name brands or a local no name brand....I have found when i run one type of fuel where i am living it tends to make the gas gauge stick...but then i switched to chevron or shell and with their fuel additive that apparently cleans the system it no longer does that. Just a thought....
~jstnromero
Old Jan 21, 2009 | 02:03 PM
ggwash21's Avatar
ggwash21
my truck does this if its cold and under 1/4 and also if i fill it up while running and the pump auto shuts off and i don't close the cap soon after. For example i let it fill up while i was cleaning windows i heard the clunk of the handle shutting off i finished windows and then i closed cap. It was fine for 5 mins then i heard a DING and it was the low fuel light then it took about an hour to go from E to F its done this about 3-4 times in the last 5 months. but all lead back to filling up while vehicle was running
Old Jan 21, 2009 | 10:23 PM
irishammer's Avatar
irishammer
I have filled my 04 with the engine running or shut off and have not experienced this....I will have to watch!
Old Jan 21, 2009 | 11:01 PM
Hank85713's Avatar
Hank85713
my son says it happened a couple of times in the past but it recently has been happening more often. Says he has never refueled with the engine on or key on.
So this seems to be another idiosyncracy of the ford trucks I guess.
Old Jan 21, 2009 | 11:04 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
be careful doing that. your truck may throw a CEL on you. The PCM monitors gas tank pressure while running to detect leaks
