6.0 tranny cooler fittings
So I scored a 6.0 tranny cooler for $75 from the breakers, and now I need fittings. I bought a bunch of fittings from my local Lowe's, but it's 3 pieces for each line. $23 out the door. Not too bad... but .... I found these:
ebay auction: Pex 3/8" x 1/2" reducing coupler
1. I try not to waste money... too much!
2. No putting together means fewer joints & possible leaks
Anyone out there have experience with this brand? Seems like it'd work perfect and be tons cheaper. They are brass and a worm-gear clamp over the hose could be good & tight.
For $15 I'd have plenty of spares & would gladly share out the extras. I called a local plumber but like many people, couldn't see that this item could have any other use besides home plumbing. I explained what I wanted it for 3 times and he still didn't get it. "You sure there's not like 3000psi in that line?" No, in fact I'm not, but given that it's just rubber hose in there from the factory, I'll be a little crazy and risk it....
So then here's both questions I currently have:
1. Anyone with experience/knowledge on the suitability of this item for how I want to use it?
2. Who else would want a pair?
I got my stuff from BTS. But the pex fitting is a solid brass piece, cant see any issues with it. The way its normally used, is with a copper ring, that gets crimped down, squishing the hose between the ring, and the fitting. I redid the plumbing in my house, and ditched the copper, and installed a pex manifold, and lines. You might look into the crimp setup if the hose is small enough to fit under the copper ring. Would look nice. As far as the fitting goes, IIRC water lines in the house, after the regulator is usually around 65 psi or so? Cant see using them for that would be an issue. So long as you can clamp them down good onto the fitting.
I'll have a spare pair. Just PM me your address is all and when I get them I'll send them out via 1st class mail.
