Stock Operating Temp?
Old Jan 19, 2009 | 06:11 PM
david00f150's Avatar
david00f150
What is the stock operating temp. for a 5.0L?
Old Jan 19, 2009 | 08:29 PM
EPNCSU2006's Avatar
EPNCSU2006
Stock thermostat should be a 192-195° rating. My truck hovers right around 190 with an OEM thermostat.
Old Jan 19, 2009 | 08:34 PM
Conanski's Avatar
Conanski
The thermostat should have a 195deg rating and under normal conditions the engine temperature will fluctuate 5-10 degrees around that point.
Old Jan 20, 2009 | 07:02 PM
david00f150
I have a 190 degree thermostat in it but it runs about 210-220. I have relplaced old radiator because it needed to be changed anyway. May check the fan clutch see if changing it may help.
