I am looking for a scematic of the door wiring for an 02. I am putting an 07 cab on and need to find out what all the wires do so I can solder them to the 07 door plugs. Thanks in advance
Does the 02 have the current wiring now? Can you just make notes of what wire goes where, or is it too late for that? If pictures would help, I can try to get pics of the wires going to the switches on my 02 so you can see what color goes where.
The 07 doors have plugs at each door so you can just unplug them. I need to use the doors and cab so I thought I might as well take advantage of the plugs at each door, it will also be easier to wire up the turn signals in the mirrors.
I guess that makes sense. Can you just cut your existing wires then and check for continuity at each pin of the connector, or just compare the wire colors on the connector to where you cut it at the door, then compare the colors at the same pin location on the new truck to figure this out?
