oxygen sensor
Old Jun 15, 2002 | 06:20 PM
302man's Avatar
302man
oxygen sensor
I put true duals a while back but i replaced the headpipes and when i put the oxygen sensor back on i put it on the right side, before it had a little h pipe and the sensor was rigyt in the little h pipe between the two exhaust pipes . would this cause the check engine light to come on. My check engine comes on when ever i drive over about 60 mph could that be why or is it some thing else. Thanks for any help.
Old Jun 15, 2002 | 08:25 PM
MustangGT221's Avatar
MustangGT221
oxygen sensor
Yeah, that could be the problem, and if so, it will make the engine run very rich. The oxy sensor has to be in that lil h-pipe.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds .
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Old Jun 15, 2002 | 08:51 PM
Bronco894x4's Avatar
Bronco894x4
oxygen sensor
I just had true duals put on my 89 Bronco 302 and had the O2 bung placed between the two pipes as close to the original position as possible. I haven't had any problems.
Bronco894x4
Old Jun 15, 2002 | 10:51 PM
JTY's Avatar
JTY
oxygen sensor
