2nd gear grinds.....sometimes
Old Jan 21, 2009 | 05:47 PM
Dr. Dirt's Avatar
Dr. Dirt
I haven't driven since I told dad about it on Monday. he drove it yesterday and said it didn't grind one time. I'll drive it tomorrow and see if it happens some more or not.
Old Jan 21, 2009 | 08:21 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by Dr. Dirt
dad... drove it yesterday and said it didn't grind one time.
LOL! :)
"if ya can't find'em grind'em ;)"
Alvin in AZ
Old Jan 21, 2009 | 08:28 PM
Dr. Dirt's Avatar
Dr. Dirt
that's true. of course since the truck is still in his name I don't think he would try to mess up anything up.
Old Jan 21, 2009 | 08:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
oh, I'm sorry I forgot to say that it's the 3 speed on the column.
Ford type 3.03 3 speed manual all syncromesh transmission.
Usually all you need are the brass syncronizer blocker rings, the syncro shoes and the snap rings.
Rarely do you need to replace the entire syncronizer assemblies, which are BIG BUCK parts.
There is one blocker ring for 1st gear syncro, two for 2nd/3rd gear syncro.
Each syncro used three shoes and two snap rings.
The same parts were used from 1963 thru 1996, so should be EZ to find at NAPA, indie parts stores.
You will also need the gasket set, and while you have it apart, replace the front & rear bearings and seals.
If you want the Ford part numbers, I can type 'em all in about a minute. Then NAPA can cross the Ford part numbers over to the brands they sell.
56/78/92EFFIE
Nov 10, 2016 01:53 PM
Ford-N-floored
2015 - 2020 F150
Nov 27, 2015 09:37 PM
tananaBrian
Oct 9, 2015 05:51 PM
wilsel
Apr 18, 2014 02:39 PM
buckshot gumbo
Mar 25, 2012 09:07 PM
