Transmission swap
Old Jan 18, 2009 | 04:37 PM
Pappys53's Avatar
Pappys53
Transmission swap
Any of you darksiders with a sbc installed tranny with overdrive? Thinking about going with the 200-R4 since it is close to the same lenght as the 350. Hopefully will not have to do anything with the drive shaft.
Old Jan 18, 2009 | 05:22 PM
Old F1's Avatar
Old F1
Try this;
200r4 swap for a th350
or goggle "200R4 same length th350" around 4000 hits?
Old Jan 18, 2009 | 06:43 PM
55 f350's Avatar
55 f350
ok i'll make the bad joke ..... why not swap the belly button for a ford ??????????? 200r4 as they are still easy to find round here , and i beleive other than moving the mount back shouldn't be any other issues , and i beleive they still use the cable instead of electronics to control them . done the reverse swap on a cuz's 85 camaro and i didn't touch the driveshaft other than i want to say change the yoke , and the mount .
Old Jan 18, 2009 | 08:03 PM
sdetweil's Avatar
sdetweil
200r4 is the same length & spline as the 350..
make sure you get the TV cable adjusted right, else you will burn it up, quickly (like the ford aod)
I have done this swap in my sons 66chevy pickup..
Sam
