Ok my Headlight switch failed, I went to NAPA and picked one up got home put it in and it instantly got warm to the touch. Is that normal for a new switch?
I was worried about it gettin hot and toastin the truck, so pulled the plug on it and came in to post this.
Any input would be greatly appreciated
Keith, it's not unusual for a headlight switch to run warm. It is unusual however for it to happen instantly. What caused the switch to fail in the first place? Heat indicates one of three things is happening. First is something in the lighting circuit may be shorted to ground. Second is there is more resistance in part of the circuit than should be. Third is the circuit is overloaded.
Here's a few suggestions of things to look for.
Bare, chafed, smashed wiring. Places where wires pass thru sheetmetal or frame crossmembers are my usual suspects for this kind of damage. Also a light socket full of water makes for a nifty short circuit.
Corroded connections drastically increase resistance. Since these trucks were underwired to begin with corrosion can make big problems.
Extra lights added to a system that was pretty much strained when it was built draw more amperage than the system can handle. 5 added cab lights isn't a problem. Lots of extra marker lights or adding a trailer without adding relays is.
Usually the first symptom of a light switch failure on these trucks is the headlights will go off and come right back on. This is caused by an internal circuit breaker that is built into the switch. Each time the breaker trips it gets a little weaker. It doesn't take long until the breaker will no longer reset and the headlights won't work at all.
I don't know how bad the wiring in your truck is but after 35+ years a lot of these trucks have had their share of poor quality wiring repairs. Butchered is the term I like to use.
The headlights were originally wired with what looks to be 16ga wire. This was marginal to begin with. What does help here is to add a relays for the headlights. One for low beam, one for high beam. They can be mounted on the rad support and utilize the original headlight wires to turn the relays on and off. I like to use 12ga wire but I wouldn't use anything smaller than 14ga.
If you have some type of fog or driving lights these should be wired thru a seperate relay.
Trailer lights also should be wired thru relays. This not only helps the life of the light switch but also takes a lot of strain off of the turn signal switch. The lights will be brighter too. Here again I'd go with 12ga wire.
Something you'll have to take into consideration is how to power all the relays you plan to add. I've seen many vehicles with wires added to the battery terminals or the feed post of the starter relay ( often called the solenoid ) on Ford products. Rather than creating potential problem areas I have a suggestion. Mount the relays together as a bank and run one or two wires from the feed post of the starter relay to power all of them. The inner fenders have several places that could be used. I would use 10ga wire for the relay feeds. Also don't forget to add a good ground for the relays.
These trucks used seperate flashers for the turn signals and 4 ways. Chances are the turn signal flasher has failed. They are both under the dash but I don't remember where. To figure out which is which turn on the 4 ways and grab the flashers by hand. The one that's clicking is the one for the 4 ways.
Keith,
I forgot to mention, don't be tryin' to use halogen or high powered headlamps with this old wiring unless you do the relay setup. They draw more power and will burn up wires and switches.
Gene
Check to see if one bulb is burned out or not connected on the side that flashes quickly. Usually when a bulb bites it, the cycle time will speed up considerably.
If the hazards also flash quickly, you might have both turn signal bulbs out in the front or the back, or one of each.
