Blinker lens removal
Old Jan 17, 2009 | 11:54 AM
HH60FE's Avatar
HH60FE
I've got a marker light out, next to the right front blinker, and I've spent an hour trying to fighure how to remove the darn thing. How do you get the lens out to get to that light? I've done a search and can't find anything. Anyone know how this is done? Thanks much.
Old Jan 17, 2009 | 11:58 AM
ron's power stroke's Avatar
ron's power stroke
2 srcrews at the bottom..then pull strait out..try not to twist the lense..there is a plastic peg the pushes into a rubber oring..you will break that peg if you twist to much...after you get it off..put a dab of grease on that peg..next time you go to pull it off..it will come off much easer
Old Jan 17, 2009 | 12:06 PM
HH60FE's Avatar
HH60FE
Thanks, I didn't wnat to pry too much till I got a second opinion. I'm on it.
Old Jan 17, 2009 | 12:14 PM
HH60FE's Avatar
HH60FE
All I had to do was press the "easy" button (click on FTE) and small task done.
Thanks
Old Jan 17, 2009 | 12:17 PM
ron's power stroke
lol..glad you got it..
