It's in order of what I did, but if I were to do it again, I'd do the tranny mods BEFORE the chip. Also, I have a bigger tranny cooler coming. If I towed often, that would've been done sooner as well. So, to start:
That will get you started. Also, look at the in-tank mods (Hutch/Harpoon), CCV mod, and HPX. Those are good mods as well, and don't really need to be done in any particular order, but are helpful to keep the fuel from being aerated, keeps the engine clean, and helps smooth out the idle.
Welcome to FTE edf250. You have found the best forum on the net. Felloy Izzys list and You can't go wrong. I have not started mine yet (takes money and had a bad year) but I have the same list.
