1979 Ford Engine Swap Question
Old Jan 16, 2009 | 10:54 PM
1979FORD400's Avatar
1979FORD400
Question 1979 Ford Engine Swap Question
Will a 1986 Ford 460 fit in a 1979 Ford F-150 with a 400m and a c-6?
Old Jan 16, 2009 | 11:39 PM
plowpusher's Avatar
plowpusher
yes but you will need the motor towers out of a 460 truck and all the accessory brackets
for a truck motor and exhaust manifolds probably all out of a 73-79 era truck be cause I know those clear the frame. or you could go with L&L specialties a place in Kansas that carries all kinds of kit stuff to make this swap. just google them.
Old Jan 17, 2009 | 03:18 PM
1979FORD400
79 pulling pickup
i'm tryin to make a pulling truck out of this 79 and the 460 needs a rebuild any suggestions on parts or maching i should do with it? how about the tranny probably need to build that up to right?
Old Jan 17, 2009 | 03:40 PM
Dr. Dirt's Avatar
Dr. Dirt
here is the link to the forum for 460s.
https://www.ford-trucks.com/forums/forum53/
here is the link to the forum for transmissions.
https://www.ford-trucks.com/forums/forum69/
the people here know a lot, but if you go to those forums you'll probably get some better responses.
