Rain leak
Old Jan 16, 2009 | 10:29 PM
johnnycool's Avatar
johnnycool
Rain leak
Ok I thought my wet carpet on the passager side was from the AC condosation. but now I don't think so. I haven't used the AC in a while and the floor has staied dry. The other day it rained and the edge of the carpet was wet. I pulled the trim and the channel under it wear they run the wires was full of water and when it over flowed it wets the carpet. I looked all over and ran water all over the front and can't find the sourse. any ideas?
Old Jan 17, 2009 | 12:27 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
do you have a moonroof?
and check your 3rd brakelight. it may be leaking and letting water work its way to that side
Old Jan 17, 2009 | 01:38 AM
johnnycool's Avatar
johnnycool
No moon roof, I thought of the brakelight, but I have not seen anywetness in the rear that I know of but I am going to seal around it just in case.
Old Jan 17, 2009 | 02:28 PM
shemp68's Avatar
shemp68
my rear brake light leaked like a water fall in the car wash,hit headliner first.07 crew.
Old Jan 17, 2009 | 06:12 PM
johnnycool's Avatar
johnnycool
that is why I'm not sure it is the brake light, couse nothing in the rear is wet, My brother in laws 04 drips on the back seat
Old Jan 17, 2009 | 08:11 PM
dlgentry's Avatar
dlgentry
Door Seals Dude, My Ranger Does The Same Thing, It Looks At Little Flat Thats It . Cheap To Fix
Old Jan 22, 2009 | 06:50 PM
matrix660's Avatar
matrix660
I had the same problem for months. It turned out to be a leaking seam on the right fender. They pulled it all apart and resealed everything. To the best of my knowledge, it took care of the leak.
Old Jan 30, 2009 | 08:38 PM
johnnycool's Avatar
johnnycool
Update:
First I drilled a small hole to drain and water out of the channel, and got the carpet dried out resealed the 3rd brake light and check the door seals and finder, didn't see nothing. It rained the other day and the carpet was dry, but that could be becasue of my drain hole. Now my 00 Tahoe has the same issue
mr.fordneck
20
Aug 20, 2013 08:39 AM
Skoiv
2009 - 2014 F150
Aug 11, 2013 06:06 PM
royt911
1983 - 2012 Ranger & B-Series
Sep 15, 2009 05:49 PM
bdrummonds
Apr 23, 2007 10:04 AM
falconer
Aerostar
Jan 16, 2005 06:58 PM
