oil pressure
Old Jan 16, 2009 | 02:18 PM
mrfixit290's Avatar
mrfixit290
oil pressure
its cold in chicago when i started up the truck and oil pressure gage did not move it took about 20 sec to move and the oil light to go off. I have a 2000 v10 what could be the problem
Old Jan 16, 2009 | 02:23 PM
whjco's Avatar
whjco
You may be running oil that's too heavy weight for extreme cold conditions. What are you using?
Old Jan 16, 2009 | 02:33 PM
mrfixit290's Avatar
mrfixit290
5w30 i think
Old Jan 16, 2009 | 03:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
Well, no problem with the oil weight then.
Cold weather does weird things.
If it does it again on a cold start I would first change the oil & filter. Make sure you use a GOOD filter. I prefer Motorcraft FL-820S from Wal-Mart.
If it persists then the oil lift pump is bad or heading that way
