Leaf Spring differences
Old Jan 16, 2009 | 02:16 PM
sdstriper's Avatar
sdstriper
I have two trucks, 84' 2wd and 86' 4wd, both half ton. Is there a difference in the rear leaf springs?
Old Jan 16, 2009 | 06:57 PM
hittman1422's Avatar
hittman1422
they are a different width... dont quote me but i think one is 2 1/2 and the other is 1 1/2(inches that is) someone who knows more than me will be able to tell you exactly... good luck!
Old Jan 16, 2009 | 07:16 PM
hittman1422
i found a thread awhile back when i was doing homework on a 4x4 conversion, said the skinnier leafs were more flexible (better ride on road) but the thicked 4x4 springs are much stiffer and give better off road performance... supposively you can switch them fairly easily. try searching 4x4 or 4wd conversion in the search engine, might tell you a bit more.
Old Jan 16, 2009 | 09:54 PM
Franklin2's Avatar
Franklin2
The 2wd spring is 2 1/2 inches wide, the 4wd has 3 inch wide springs. It's a pain to swap them because you have to swap out the spring hanger brackets riveted to the frame.
Old Jan 18, 2009 | 06:21 AM
sdstriper's Avatar
sdstriper
I'll hit the yard then, Thanks!
