cold starting problems.
Old Jan 16, 2009 | 05:46 PM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by caleb90
that isnt bad i was exspecting alot worse.
I think I paid a little higher - like $190 - but depends on where you are at. Easy fix though. Unhook batteries, loosen the serp belt, unplug the one wire harness, loosen three bolts and remove. Reverse order for install.
Old Jan 16, 2009 | 05:49 PM
jermort's Avatar
jermort
Originally Posted by MTGunner
I am wintering in SW New Mexico. It has not been below 32 degrees for some time. I have had difficulty starting my '01 F250, 7.3L diesel twice now. I let the glow plug light go out and try to start. It will fire very briefly then stop. This happened to the point, this AM, that I squirted a 1/2 sec. of starting fluid into the intake. It started right up. Am I perhaps looking at a glow plug problem? Thanx for the input.
Personally, I wouldn't use any ether on my truck. That stuff is just plain dangerous. Your GPR will stay activated for up to 2 minutes. I always wait at least 30 seconds before I crank when it is below ~45. The extra heat in the GPs really helps with cranking a cold motor. If it is really cold, let the GPR cycle completely then turn the key off the on for a second cycle. That will add extra heat in the cylinders and make cranking a lot easier.
Have you checked your GPR? That'll cause your issue also.
Give it a try, it really helps.
jer
Old Jan 16, 2009 | 05:56 PM
MTGunner's Avatar
MTGunner
GPR location?
Is the GPR relay in the under hood fuse box?
Old Jan 16, 2009 | 06:05 PM
jermort's Avatar
jermort
actually it's on the top of the motor.
Take off the plastic trim thingy on the front of the motor and it's the big *** round relay right behind on the passenger front side of the motor. Easy to spot has 4 lug connections on the top, three of which have large guage wires connected. The other connection is the signal lead from the PCM. The relay is controlled by the computer.
hope that helps, go to napa and they'll show you one if you're unsure of what your're looking for.
easy to change, common failure.
jer
Old Jan 16, 2009 | 06:09 PM
ron's power stroke's Avatar
ron's power stroke
not trying to be a azz ..but you will get better help by starting a new thread..some times if you have 2 differnt questions in one mans thread.it makes things hard to fallow...
Old Jan 16, 2009 | 07:58 PM
Tenn01PSD350's Avatar
Tenn01PSD350
yup the alternater is shot.just tride to go to town, and i had to turnaround because my dash lights were getting dimmer and so wernt my head lights.my voltedge meter was also dropping.how much doone of things things cost.probly a dumb question but this is my first diesle so i dont no if it would be more exspensive than a gas motor alternater.
Dude, you are having a real bad day. I hope the wife doesn't run off with the mailman or some chit. Anyway, I would ideally like to test it with a VM to make sure it is the alternator and not toasted batteries. Make sure wiring is good, and before replacing it, remove both batteries and the alternator and have them all tested. It would suck to buy a new alternator only to have chitty batteries run it into the ground. I hope things get better for you bro.
Old Jan 16, 2009 | 08:26 PM
caleb90's Avatar
caleb90
Temporarily Deactivated
it defenatly has been a bad day,but things will eventully get better.tommoro im gonna test the alternater and the batt's.I got a price for a new alternater at 120 bucks wich is pretty cheap from what every one is saying they usaly run.
Old Jan 17, 2009 | 10:06 AM
redfire42's Avatar
redfire42
when i reved it up a couple time to try to get it to fire,i went went around my truck to my tail pipe.and there was fuel on the snow,from were it blew out.i was just worried about cylinder wash.
Plus I would never rev a cold motor to try and get a cylinder to fire. You could be looking for more problems. Molasses doesn't flow to well when cold. And to have fuel on the ground you must have stabed the thottle pretty good.
Old Jan 17, 2009 | 12:24 PM
caleb90's Avatar
caleb90
i waited for the temp gauge to go up before i reved it up.And when i reved it up i held it about 1500 rpm.
Old Jan 17, 2009 | 12:30 PM
FARM69's Avatar
FARM69
x2. I wouldn't recommend reving a cold engine. That cylinder should be firing by the time the needle moves on the stock temperature gauge.
