TC/ manual lock Question
Old Jan 16, 2009 | 12:27 PM
redfire42's Avatar
redfire42
Question TC/ manual lock Question
I was wondering, I have the manual lock for the TC. When I warm the truck up before I go anywhere it takes forever for the heat to build up to lock the TC. I was wondering if it would hurt anything it I manualy lock the TC when cold? I will not be hamering on it just want to bring the RPM's down on a cold motor when driving so I wont get run over by the " In a hurry people" that follow me.
Old Jan 16, 2009 | 03:46 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Bump....... I don't know.
Old Jan 16, 2009 | 04:50 PM
ron's power stroke's Avatar
ron's power stroke
i had a SP diesel tc lock on my truck..it locked TC every time at a set speed..i set for 32 MPH in the winter for 2 winters..the stock TC did let go...but it had 165k at the time...not sure if the cold played a role in there or not..i did go easy till things had a chance to warm up...
Old Jan 16, 2009 | 07:01 PM
rblaine9000's Avatar
rblaine9000
What is this manual lock? How do I get it where and how much?
Old Jan 16, 2009 | 07:31 PM
white Buffalo's Avatar
white Buffalo
I'm a little confused about your question. I was under the assumption that the TC lockup was a function of speed. 35 mph for lock and will unlock when the brake is applied unless in tow haul mode of your tuner has set the TC control on the chip to different parameters........
As far as I know it is a matter of RPM's for the TC. Too low of an RPM and you can do some damage over time. I'm not 100% sure but I believe it is in the neighborhood of 1500 rpm's.
From Forgotton Ford's website:
"First off, you DO NOT want to "lug" your automatic transmission by locking it in first gear at
an idle. The line pressures on the lockup plates are NOT HIGH ENOUGH at idle to hold the lockup
clutch and you will burn up your torque convertor over time. The primary purpose of the TC lock
mod is for TOWING. The TC lock mod, combined with an exhaust brake will allow you to travel down
long grades with minimal use of your service brake. This equates to cooler brakes at the bottom,
and longer brake life.
The TC lock mod is also good for long uphill driving at speeds BELOW lockup speed (about 45mph).
Keeping the Rpms up by using 1st or 2nd gear and locking the TC will allow you to keep tranny temps
down during long uphill (and uphill towing) situations. You should unlock your TC at speeds below
about 25mph or RPMs below 1000 so as to avoid TC damage from low line pressures.
Old Jan 16, 2009 | 07:32 PM
powrstrkn''s Avatar
powrstrkn'
The T/C being locked up should reduce heat in the trans. I've done it in the cold with no ill effects. I say go for it
Old Jan 16, 2009 | 07:37 PM
ron's power stroke
when its down near 0 the tc locks up late as you role out of the drive way,,,,it lets the the trans build up some heat be for it locks...some times if i just drive out of town..its down hill for about 2 miles.....it will shift into OD before the tc locks..
Old Jan 16, 2009 | 07:40 PM
white Buffalo
Blaine,
Here is two websites that explain the mod:
Torque Convertor Lock-up mod
Welcome to guzzle's TC Lockup Mod Web Page
Old Jan 17, 2009 | 09:58 AM
redfire42's Avatar
redfire42
Thanks for the replys, I work second shift or I would have been back sooner.
I know the tranny doesn't lock when cold. And with a cold motor I don't want to push the RPM's to high but want to be up to or close to the speed limit. When locking the trans it would be when up to or close to speed there for not putting any strain on parts. I just didn't know if it was a safe thing to do with a cold tranny.
I am talking about a manual lock Vs the ECU locking.
Old Jan 17, 2009 | 12:17 PM
white Buffalo
Got it - I just didn't get it at first. My bad. Seems like you should be good as long as the speed is above 25 and the RPM's above 1,000 to keep the line pressure up.
Old Jan 17, 2009 | 04:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I would not let it lock below 1300 RPM to be sure there is enough pressure to maintain the lockup without slipping.
Old Jan 17, 2009 | 04:55 PM
white Buffalo
Well, Mark is a transmission expert - so I would follow his advice on this.
Old Jan 18, 2009 | 08:11 AM
redfire42's Avatar
redfire42
yeah I never lock it below 1500/1800, it just feels like I am luging it to much when cold it I do that.
I did notice though that when its warm out and I lock it manualy and I do get down to 1000/1100 RPM's theres no slipping. But I am only down there for a few seconds.
Thanks for all the advice guy and Rich sorry I am not that best at explaning myself. I guess its something I need to learn.
Old Jan 18, 2009 | 08:25 AM
white Buffalo
nah, think I was the one not getting it - everyone else seemed to......
Old Mar 9, 2009 | 02:59 PM
03F2507.3's Avatar
03F2507.3
Blaine,
Not to bring back on old thread but the Guzzle method seems awfully involved compared to the one from forgotten.net?? Has anyone had experience with them both and can tell if one is better than the other? Or is the forgotten.net a little too simple and can hurt the tranny or computer?
