windshield noise
Old Jan 16, 2009 | 08:37 AM
colttodd's Avatar
colttodd
windshield noise
When my truck gets above 55 mph I start to hear a crackling noise (like ice hitting the windshield) around the passenger side windshield-dash area. I took to the dealer ship and they refastened the seatbelt mount. I told them I did not think that was the problem because it only made the noise when the truck was going over 55.
Any way the next day after getting the truck back its making the same noise.
Nothing seems to be loose inside or outside of the truck. Any ideas?
Old Jan 16, 2009 | 09:39 PM
bullredguy's Avatar
bullredguy
has the windshield been replaced?
Old Jan 17, 2009 | 08:54 AM
colttodd's Avatar
colttodd
no bought the truck new a few months ago.....and nothing seems to loose.
Old Jan 17, 2009 | 09:52 AM
fordman19762003's Avatar
fordman19762003
my 05 does the same thing, and it got worse after I put the bugshield on. I think I read on here awhile back that maybe the noise was coming from the rubber trim along the top of the windshield.
Old Jan 17, 2009 | 10:32 AM
jr105's Avatar
jr105
If you want to verify that put duct tape over the suspected area and see if the noise goes away.
Old Jan 17, 2009 | 11:32 AM
bullredguy's Avatar
bullredguy
good answer jr also look at the bottom cowl mldg at the base of the glass in cold temps it has a tendency to make funny noises also there was no upper glass mldg as the truck came from the factory with the so called clean look
Old Jan 17, 2009 | 02:15 PM
TRX250R87's Avatar
TRX250R87
windshield noise
My 05 sounds like the windshield is about read to fall out when the temps get down to the single digits.
Eric
Old Jan 17, 2009 | 02:43 PM
shorebird's Avatar
shorebird
Use blue painters tape instead of duct tape. It will remove with out leaving any adhesive residue. If the problem is the trim (probably is) a little trim adhesive will do the trick.
sr23
May 4, 2014 03:09 PM
WillFargo
Oct 22, 2009 08:33 PM
scalder27
1983 - 2012 Ranger & B-Series
May 4, 2009 01:27 PM
burner879
2004 - 2008 F150
Nov 7, 2007 12:50 PM
haskinsguy
Feb 3, 2004 07:32 PM
