Carb Questions
Old Jan 16, 2009 | 07:47 AM
Raff Riff's Avatar
Raff Riff
Carb Questions
I need to do something with my carb. It is a Holley 2bbl. Should I replace it with a rebuilt Holley? If so, which, the 350 or 500cfm? Or rebuild it? Or should I just switch back to a Motorcraft? And why?
Old Jan 16, 2009 | 03:37 PM
fmc400's Avatar
fmc400
MSEE
In general, it's more economical to rebuild the carburetor you have. The Motorcraft is an excellent carburetor, some people prefer the Holley because the Holley has the power valve mounted horizontally whereas the Motorcraft has it mounted vertically. If I were you, I'd just rebuild what you've got assuming you can find a reasonably priced rebuild it.
