on my 94 f150 the abs light started blinking after i pulled a car trailer threw a foot of snow in 2wd in first gear to the mat. it was low on tranny oil so i added some and it came off drop 100km then it started blinking again, tranny oil is full dont know what else it could be... anybody have this problem and know how to fix it?
it blinks 16 times really quick and on the 16th time it says lit for a second.... and my airbag light binks 3 times then 2 any idea what that could be to?
I am not sure. Those do not appear to be codes usually they are 3 digit. Maybe someone else will chime in. In the mean time Autozone may be able to get the codes off. How many miles on the truck?
ya my horn works cruise control dont work anymore tho. i think it might just be a fuze. now the air bag light blinks 5 and 1 instead of 3 and 2. still havent figured out the abs light
My abs light came on once when I pulled a trailer with bad wiring that blew the fuse. The fuse for the abs is the same as the brake lights and the automatic trans shift interlock. Not sure if you have an auto but when mine blinked the lights didn't work and I was stuck in park.
The code 32 for the airbag is more than likely the clockspring. Mine is shot too and that is how it started. airbag first, then horn now cruise. My whole wheel is dead and that damn light wont stop blinking(under the black electric tape now) Going to replace in the spring when I can stand to work outside.
Not sure what the code 51 is, might have to call the dealer on that one. I don't know where else to get airbag codes since they really don't want regular joes working on the system.
Glad to hear you figured out your other problem.
