Weird fuel leak
Old Jan 15, 2009 | 04:32 PM
frenchslandscape's Avatar
frenchslandscape
Weird fuel leak
I don't know what its called but it looks similar to a valve stem near the fuel filter and there is an air fuel mix coming out of there any ideas?
Old Jan 15, 2009 | 04:39 PM
RCrawler's Avatar
RCrawler
It is the air bleed for the filter head/ system. It is very similar to a tire valve stem. You may need to tighten or replace the valve core.
Jason
Old Jan 15, 2009 | 05:40 PM
F250FarmBoy's Avatar
F250FarmBoy
If you dont have the handy tire valve with built in remover (like my old equipment has), take a cheap pair of needle-nose pliers and grind them down to fit into the valve core and tighten it up a little if you can. Dont go hulking on it, just snug it up a little to see if it make a difference.
