is it worth it
Old Jan 15, 2009 | 04:14 PM
lowharley's Avatar
lowharley
is it worth it
Found a 02 F250 CC 4x4 lariat, 7.3 with 180,000 miles. Out the door with tax and everything $11000. Should I be concerned about the miles, do not need it but about 6 times a year but will be traveling some distance when I do use it.
Thanks in advance!!
Old Jan 15, 2009 | 04:22 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Are you going to drive it more then 6 times a year? These trucks don't like to sit idle. Have someone look at the truck that knows diesels, (7.3 preferred).
I would also try to talk them down a little if you can. Good luck.
Old Jan 15, 2009 | 04:27 PM
Ponyboychris's Avatar
Ponyboychris
Thanks in advance!!
All depends on the condition. 180K on the clock can be "just broken in" or "beat to death" or anything in between. Any chance of service records, signs of mods, gooseneck hitch and/or trailer control box? Have the dealer (I assume its a dealer you are looking at) run an OASIS report for warranty fixes. It's not in it's warranty period anymore but at least you can get a feel for it's previous life.
Old Jan 15, 2009 | 04:28 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Where is the truck? There may be someone close by that could help out. If you update your profile also that would be good. (in the blue bar click on User CP)
The dealer may just come back with a CARFAX report (mine did) but I believe in the 6.0 forum there is a sticky at the top where you can request an OASIS report.
Old Jan 15, 2009 | 04:31 PM
PaysonPSD's Avatar
PaysonPSD
CLICK HERE for a buyer guide. Good Info.
Old Jan 15, 2009 | 06:29 PM
lowharley's Avatar
lowharley
Thanks for all the info..
I will be driving it more than that but will only being hooked to a gooseneck about 6 times a year. Trips range from 600 to 1000 miles roundtrip. It has had a gooseneck hitch but it has been removed. Other than that I don't have any more info.
drh1175
6.4L Power Stroke Diesel
32
Jul 16, 2010 07:05 AM
robs01f250
May 9, 2009 07:06 PM
drfbuster
Apr 7, 2005 06:33 PM
98150
1997 - 2003 F150
Apr 25, 2004 10:07 PM
Hamstersbane
Jun 29, 1999 10:06 PM
