Speedo
Old Jan 15, 2009 | 11:23 AM
Scifi266's Avatar
Scifi266
Speedo
I have recently done a body swap of my 66 f250 onto a 1975 f250 4x4.
This 1975 has a 390(Transplant) a divorced transfer case, and a C6 Auto.
Everything is going great except the speedo cable that goes to the transfer case
has a different style hookup to the back of the instrument panel. The 66' has a T18 Manual tranny, and the original speedo cable hooks up to the tail shaft. Just wondering if there is a kit i can get or what?
Thanks in advance.
Old Jan 16, 2009 | 01:00 PM
Roger Carter's Avatar
Roger Carter
Check with a local speedometer shop. They can build you what you need. Don't know where you are located, but in the Portland Oregon area it cost me $32.00 for a new, custom length, cable and housing for my '66.
Good luck.
Roger Carter
Old Jan 17, 2009 | 09:52 PM
customcab66's Avatar
customcab66
try seeing some one can change the ends to fit them think that it is a krimp on peice not sure
