Sponsored by: Real Truck
Water pump help!!
Old Jan 15, 2009 | 10:48 AM
Vankaye's Avatar
Vankaye
Water pump help!!
The bolts securing the pulley to the waterpump are only accessible with an open-end wrench. Of course, mine is not biting hard enough and is rounding off the bolt.
I can't get anything else on the bolts.
ANy suggestions? Can I get the waterpump out with the fan still attached and work
on it on the bench? I'm concerned about beating up my radiator fins.
My wrenches are Craftsman. Do I need a better wrench? Perhaps a 6 pt?
AHHHGGGGG I need good idea here!
Old Jan 15, 2009 | 10:52 AM
TexasRebel's Avatar
TexasRebel
if you can't get a 12pt. box end wrench on it, you won't be able to get a 6 pt. box end on it either.
Old Jan 15, 2009 | 10:53 AM
Vankaye's Avatar
Vankaye
I was thinking of a better fitting open end wrench... but I can't find one online.
Tried a line wrench too. Won't go on it.
Old Jan 15, 2009 | 11:01 AM
senix's Avatar
senix
I think that craftsman came out with something that will grip on that check here:Find Craftsman available in the Bolt-Out, Taps & Dies.Discover Tools and more at Sears.com
Old Jan 15, 2009 | 11:05 AM
Vankaye's Avatar
Vankaye
Those would work if I could put a socket in that space... then again if I could use a socket the bolts would not be rounding!
I haven't done much damage yet. Just trying to find the right tool for the job. As soon
as the first wrench slipped I stopped in my tracks. I haven't hacked up the bolt heads yet...
Old Jan 15, 2009 | 11:55 AM
rwilimo's Avatar
rwilimo
You need to take the fan off first, this will solve all your problems.
Old Jan 15, 2009 | 12:01 PM
12ozd's Avatar
12ozd
That's kinda what I was thinking.
Old Jan 15, 2009 | 12:11 PM
Vankaye's Avatar
Vankaye
Doesn't the pulley hold the fan? Or is the big nut on the fan shaft threaded
to the waterpump shaft?
The bolts (circled red) won't those release the fan and shaft?
or... does the shaft (circled blue) thread onto the waterpump?
Looks like somebody used an impact chisel to convince that shaft the last time!
Old Jan 15, 2009 | 12:41 PM
SpringerPop's Avatar
SpringerPop
Let's get some clarifications:
First, you ARE using metric wrenches, aren't you?
Second, (from what I can see) this IS a 7.3 diesel engine, right?
I may have missed something along this thread, but I can't find where you mentioned the engine. A lot of people come to this forum asking about other engines.
Pop
Old Jan 15, 2009 | 12:42 PM
12ozd's Avatar
12ozd
You need to unthread the fan ( blue circle).
Some folks use a impact hammer / chisel to break loose the nut,then it will unthread easily.The fan threads on to the water pump.
Next remove the bolts holding the pulley on.
BE SURE TO CHECK THE THREADS ON THE FAN,SOME ARE RIGHT HAND SOME ARE LEFT.IT MAY BE WRITTEN ON THE SHROUD.
By the looks of the chisel mark,it appears to be right hand thread.
Old Jan 15, 2009 | 12:45 PM
SpringerPop
The threads on the end of the water pump shaft are conventional, right-hand threads.
There is a kit you can usually rent at the parts house for getting this apart, and it will make it a lot easier.
Pop
Old Jan 15, 2009 | 12:58 PM
Vankaye's Avatar
Vankaye
Pop
Yes, I'm using metric. It is a 7.3L.
As long as I know the shaft is threaded I will go forward with the impact chisel... It's good to know beforehand! : )
Old Jan 15, 2009 | 01:56 PM
Vankaye's Avatar
Vankaye
Thanks Guys! As you can see the waterpump is out. No Blood and no broken bolts!
Old Jan 15, 2009 | 03:30 PM
Vankaye's Avatar
Vankaye
Anybody have the torque specs for the waterpump bolts?
I really gotta get me a haynes book for this puppy. Got some other projects
in the works and I know I will need it
Edit:
Found a great link!
http://www.dieselbombers.com/ford-po...que-specs.html
Old Jan 15, 2009 | 03:32 PM
senix's Avatar
senix
don't have the spec's but I would think they would be enclosed with the new pump. At any rate I would not put a lot on them about 20-30 ft. lbs.
