Any one ever try this stuff ?
Old Jan 14, 2009 | 10:36 PM
madsonp's Avatar
madsonp
Here's a product I just noticed from one of the forum sponsers, for leaking head gasket repairs. Has any one ever used this stuff ? I wonder if it works as good as they say. Repairs Blown Head Gaskets With No Disassembly | Lifetime Guarantee | Steel Seal
Old Jan 14, 2009 | 11:35 PM
alloro's Avatar
alloro
Hmm, interesting! I wonder what happens when and if you ever pull the heads off? Can this stuff be removed? Will the head be permanently adhered to the block? Once drawn into the cylinder through the head gasket leak, will it attach itself to the piston, valve, or cylinder walls? Since it bonds in high temperature conditions, will it bond to the block inside the water jackets that surround the cylinders? Lots of unanswered questions here.
Old Jan 15, 2009 | 02:06 PM
vze2sgxa's Avatar
vze2sgxa
Why would any of the 'thousands of mechanics' mentioned use something that is just going to take work away from them (ie., pulling a head manually and repairing it thoroughly and correctly), unless of course they charge the same for 'installing' it (pouring it into the radiator.) It would be the easiest head-removal job they ever did.... yeah right.
Old Jan 15, 2009 | 02:18 PM
alloro's Avatar
alloro
Head gasket replacements are low profit jobs. They would rather put their time towards high profit jobs like coolant flushes, front end parts, exhaust, and brake jobs. That's why.
Old Oct 25, 2011 | 09:47 AM
Petervan's Avatar
Petervan
There are more option
There are more brands that sell a head gasket sealer
Old Oct 25, 2011 | 11:22 AM
etewald's Avatar
etewald
And what happens when you're running it for the 60 minutes and the engine seizes? Nothing that mentions that in their guarantee.
Old Oct 25, 2011 | 01:54 PM
Biggg72's Avatar
Biggg72
this question has been asked numerous times on my legend forum and the same product in question. dont use this and yes its a pia when you do eventually go to get it fixed. the crap is everywhere and hard to get it all out. there is one brand that some have used and spoke well about, but the general thoughts dont use it any of the fixes, get it fixed. i have to go back and look for the name but i think its blue devil or something like that.
Old Oct 26, 2011 | 10:01 AM
2trux's Avatar
2trux
From reading about sealers it appears that they are for use on engines you would never do a gasket replacement on because of the cost.
If your truck/car is worth less than the repair, and you would junk it anyway, I would say go for it, you have nothing to lose.
This also addresses the problem of repair difficulty as you would not be repairing it later.
SuperDuty93
Jun 27, 2012 12:10 PM
Canoncowgirl
Aerostar
Feb 3, 2012 07:36 PM
jmpopp
Aug 28, 2010 10:48 AM
bismic
Jul 29, 2010 09:18 PM
dave at BD Power
Jun 6, 2010 09:26 PM
