56 f7 steering column
Old Jan 14, 2009 | 09:56 PM
56f750's Avatar
56f750
how do I seperate steering column from gear box? want to pull steering column
Old Jan 14, 2009 | 10:24 PM
Huntfamily53's Avatar
Huntfamily53
I may be wrong but I dont think they come apart? You remove the whole unit as one piece...At least, that is how it is on the f100's. Maybe f7's are different?
Old Jan 14, 2009 | 10:34 PM
wmjoe1953's Avatar
wmjoe1953
You don't. The assembly comes out as a whole. You can then remove the tube. In order to remove the shaft, you have to disassemble the gear box.
Old Jan 14, 2009 | 10:51 PM
56f750's Avatar
56f750
Wink thanks
thanks- I'm an oilfeild truck mechanic and work has me redoing( can't say restoring as work won't let me everything i want to) a 56 f750 or f7 oilfeild wireline service unit for trade shows and I have to do a cab swap- as the oringinal cab is trash- i'm not familiar with 50's stuff - 70's more my style - i've had a couple torinos and a few 80's mustangs but this is my first 50's project. it's cool but uncool as I am going to have to slice up a good cab from the donor truck.
Old Jan 15, 2009 | 07:49 AM
barbsbuddy's Avatar
barbsbuddy
Why are you slicing up a good cab/ If they are both standard 1956 cabs, they are the same.
Old Jan 15, 2009 | 05:15 PM
56f750's Avatar
56f750
the truck was originally built in 1957 and they cut the back wall off and sectioned the roof and mounted an aluminum body that encompassed the cab- kinda cool how they did it back in 57-it's kinda rough and crude but it was 1957-
Old Jan 15, 2009 | 06:26 PM
WALFORD'S 56's Avatar
WALFORD'S 56
The big trucks and the small trucks have the same cab. 1956 cab -but I heard from number dummy that some 56s were actually titled 57s.
I have removed and installed 2 big columns this year and reinstalled them in 56F100s,and WM JOE is right....1 piece removal technique.....Bill
