Steering Gear Box
Old Jan 14, 2009 | 08:34 PM
dullchrome's Avatar
dullchrome
Steering Gear Box
does anyone know if there is a way to lube/service the steering gearbox on my 63 f-100 2X4?
Old Jan 16, 2009 | 03:16 PM
airharley's Avatar
airharley
Basically you have to remove the entire column/box from the truck to clean the internals out. It's almost a rebuild once you get all the parts out of it. Once they are all out wipe it down and pack it full again. A high temp grease is better since it sits right next to the manifold or header. Speaking of which I should do mine. Thanks for the reminder.
Old Jan 16, 2009 | 04:41 PM
camperspecial65's Avatar
camperspecial65
As I recall the shop manual calls out for 90wt oil in the steering box...hypoid gear oil...
Old Jan 16, 2009 | 04:42 PM
camperspecial65
the shop manual calls for hypoid gear oil...aka rear end lube for the manual steering box.
- cs65
Old Jan 17, 2009 | 04:55 AM
rsdjcarter's Avatar
rsdjcarter
- cs65
Are you sure Don my original was full of grease but a little runny I wonder if it had been mixed or if just very old? It does kinda have that rear end smell about it. Wonder if that is why the bearings failed.
Old Jan 17, 2009 | 05:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
90wt hypoid gear oil is correct.
It's prolly solidified by now, cuz it hasn't been changed since grandma was a girl.
The bearings failed because the gearbox is 44 years old. Nothing lasts forever.
I'm surprised they lasted this long.
Usually by the time one a these gearboxes is 5 years old, it's time for a rebuild.
zombiefied 247
Oct 30, 2012 04:58 PM
deadeyedevon
1978 - 1996 Big Bronco
15
Jan 4, 2010 06:12 PM
tetraruby
Nov 18, 2002 07:12 PM
Drawsoncad420
Jun 13, 2002 04:43 PM
94 ford
Aerostar
Apr 29, 2002 11:43 AM
