Fuel selector valve
Old Jan 14, 2009 | 12:53 PM
Blackwaterforge's Avatar
Blackwaterforge
Fuel selector valve
Dose anyone have a picture of the fule selector valve that is mounted on drivers side on floor?
Thank You!
Old Jan 14, 2009 | 01:29 PM
72bronc's Avatar
72bronc
fuel valve
I can only assume it is typically the same valve as on early broncos
if you visit tomsbroncoparts.com under online catalog and fuel you will find a nice pic of a manual fuel valve that should be the same as to which you are talking about
Old Jan 14, 2009 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thank You!
1961/66: There is no selector valve mounted on the floor, or anywhere else.
The only fuel tank these trucks had is the in-cab tank mounted behind the seat.
If you have selector valve mounted on the floor, some previous owner has added an aftermarket fuel tank, so the valve is not a genuine Ford part.
1967 was the first year Ford offered an auxillary fuel tank.
The selector valve is mounted on the floor, there's a switch mounted under the dash that changes the dash fuel gauge from one tank to another.
Old Jan 14, 2009 | 02:03 PM
Blackwaterforge
That is correct. The valve is aftermarket or from a later model. I believe the later models had a plate that read Main,Aux and off. Mine has the valve no plate. I would like to see a picture of the plate so I can make one for my truck.
Thank You for your replies!
Old Jan 14, 2009 | 02:39 PM
72bronc's Avatar
72bronc
switch
That's correct. my 72 bronco has a switch plate
off
main aux.
its a square plate with some screws holding it in.
Old Jan 14, 2009 | 03:06 PM
Blackwaterforge
Thank You!
Old Jan 14, 2009 | 03:47 PM
th1567's Avatar
th1567
Mine has two aux saddle tanks 15 gal each, the pointer on the valve handle points Main (center), for Main, Left for Left and Right for Right
No plate, never saw the reason to have a plate you can't read when you're driving.
My uncle's valve is also a three way gate valve...but the difference is he's got a plate and the valve is mounted on the floor between the shifter and the seat...a better set up I think.
All aftermarket stuff, not FoMoCo but I think my Uncles was dealer installed in 1970....his truck is a '70 F250 straight beast...funny shift pattern on his top loader....Reverse in Behind 1st (granny), not in Front like on both my NP 4spds.
TH1567
Put gas in the Ford and roll.
Old Jan 14, 2009 | 03:56 PM
camperspecial65's Avatar
camperspecial65
Mine has the same valve...check your mail for a pic and dimensions...
mail sent...
- cs65
Old Jan 14, 2009 | 04:05 PM
WA-SuperPickle's Avatar
WA-SuperPickle
I have one in my 63; I'll take a pic when I get home and post it, if that's "OK" with the site. (?)
OConnorRacing
Jun 19, 2014 05:36 PM
newportman
WTB - Parts & other
Dec 25, 2011 12:47 PM
JCastellaw
1966 - 1977 Early Broncos
Aug 16, 2008 08:58 AM
hotrodford_88
Nov 19, 2000 07:41 PM
