Headers and a Y pipe
Old Sep 3, 2002 | 01:17 PM
boothps's Avatar
boothps
I have a '92 F150 extended cab with a new 351w I would like to put headers on it. My passenger side manifold has a crack in it.
1) Is it a Good Thing?
2) What kind? (Brand)
3) Is it just a matter of bolting it up? (ha)
The only thing left some-what stock on the exhaust is the "y" pipe.
4) Does Summit sell an aftermarket Y pipe, or should I go down to the local Muffler shop and have one made?
Thanks for taking the time to help me.
Paul
Old Sep 3, 2002 | 03:19 PM
swirk's Avatar
swirk
The crack in the manifold is bad.
There are many different kinds of headers. I would suggest getting shorty style headers that are ceramic coated. They seem to hold the heat in best and last the longest. And are the closest to true bolt on. Full length headers are a pain. Summit sells a couple of brands of shorty style headers.
Shorty headers should bolt right up to your stock exhaust. No need to replace the y-pipe....unless you are planning to do true duals. The only thing that I had a little trouble with is the smog stuff that bolts to one bolt of the manifold on the passenger side and the support bracket for the upper intake manifold. You will need to rig something up in order to hold the smog stuff up and off of those headers, otherwise there will be the smell of burning plastic and rubber. I got tired of trying to rig smoething up with the smog stuff, so I ripped it all out. I would suggest keeping it if you live in an area that does emissions testing.
If you would rather put a stock manifold back on it, I have a pair of stock manifolds off of a 1995 F150 w/351 that I currently use as doorstops. There is nothing wrong with them. I just like my headers better. Make sure you get headers that are correct for your year and make. The EGR valve is bolted to the end of your exhaust manifold on the passenger side and you will need the EGR valve with or without your other smog equipment.
Old Sep 4, 2002 | 03:42 PM
cozmo's Avatar
cozmo
I had the same problem but my truck is a 1992 f150 with 302. I replaced my headers with bassani and an equalizer pipe that they sell and the sound is awesome. There website is proficientperformance.com. It's expensive but you wont have any complaints, I love the sound on it and people turn their heads when I go by.
Old Sep 5, 2002 | 08:02 PM
turbosek2's Avatar
turbosek2
Jer bear
2004 - 2008 F150
Jun 8, 2015 03:39 PM
parker_shelton
Jan 7, 2015 07:18 PM
snowmobile mike
Sep 22, 2012 01:54 PM
TexasGuy001
Feb 22, 2008 01:01 PM
MustangGT221
Exhaust Systems
Jun 30, 2005 01:00 PM
