How much are boots for the Bilstein shock if I went with the stock model. Then I'll just paint them black since I dont have a leveling kit.
?? Not sure what you are asking - boots are included with the Bilstein shocks. On the HD's, the shock body is yellow and the boots are blue. Kind of noticable under our trucks, but I don't mind. Love the ride they provide.
I replaced my stabilizer damper and it did not come with a boot. 4 Wheel Parts wanted $6 for a boot if I bought one. They had a red one lying around (which is what I wanted) so they just gave it to me since they were going to throw it away.
As for a stabilizer, I don't think brand is going to be too much of a concern with a stock suspension setup. If you go over 35" you might want to look into a dual setup, but a stocker is just fine with one. I bought what the shop had in stock (Pro Comp). I've been happy with it and it was a huge improvement over the "branded" stabilizer the truck came with (the dents didn't help much either from the previous owner). I wouldn't worry so much about the brand as I would the purpose. Make sure that it's designed to be a stabilizer, not just a shock. A shock is designed to operate vertically, but a stabilzer (while also a shock) is designed to operate horizontally.
For the $3 per shock difference I got the Bilstein 5100s. They are for "lifted" trucks but will work just fine on a stock height truck. My rear is stock with the front leveled. In the end, it's cheaper:
New black boots = $6 each
Cost difference = $3 each (and no spray painting needed)
HERE is the thread from my install just this past weekend
I keep my Ranchos which had about 25,000 miles on them when I replaced. You can play them like an accordion. I kept them in case some day FORD says they will replace. My 2005 truck was still a good truck, especially after I got rid of the DEATH WOBBLE.
You're talking about the FX4 "rancho" branded shocks, aren't you? Those are basically Motorcraft shocks with white paint.
I am, however, unhappy with the RS9000x's I put on my '01 - albeit it's been 7 years since I did it. THe finish rotted off from the salt on the roads, and one of them in the front has leaked. The other, like someone else warned, the adjuster has frozen up.
I'm still going to go with Ranch replacements though, because I can't live without being able to adjust them. There's no way.
ART:
You speak from two sides of horizontal opening in head!
First, you say, "the adjuster has frozen up".
Second, you say, "I can't live without being able to adjust them..."
BITE LIP, buy a set of Billsteins and enjoy the ride. It will seem like a new truck.
Oh, and answer to your question, YES, I replaced the OEM stocks, aka, RANCHO, but to the best of my knowledge, they are knock off "MONROES", NOT Motorcraft. About 1000 miles later I got what I thought was an unbelievable deal on a 2008 and I traded, with the new BILLSTEINS.
I have a 99 F-250 SD CC LWB V-10. After 173,000 miles on the stock shocks I think its time to replace them. My truck is stock, no lift. Will the Bilstein 5100's work well on my truck. I use it to push snow, hunt, and fish plus its my wife daily driver in crappy Iowa weather. Good weather she drives topless. (she drives a convertible by the way).
Just a note about the adjustable damping Ranchos: Even though there is a little oring on the adjuster housing, salt and moisture can creep past the threads on the adjuster ****. This rusts the valve solid in the shock body and the adjustment is kaput. My advise is to carefully remove the adjuster housing and pack the end with grease.
This is true!
My Rancho 9000x shocks froze like that. I tried freeing up the valve, but it was too late.
I have the same question. I have a 2004 SD 6.0L. I'm going to be putting on shocks before the end of March, when I go on the 4000 mile round trip helping Dad move towing a 16' gooseneck stock trailer loaded with books journey. My current OEM's only have 42k on them, but I'm going to be investing a decent $1000 in new tires after I get back and I want to do everything I can to make sure I take good care of that expensive rubber.
I was planning on getting the Bilstein Heavy Duty's. But if the 5100's are a better shock and aren't that much more expensive I'd be interested in those instead. But I really want to know for sure that putting 5100's on a stock truck, no lifts, no leveling, nada, will work. And it's not about how they look. While yellow and blue don't really do anything for me, it's a truck, it's purpose is to work, not look purty.
You have to go to the RS9000 (cost is about $99 a shock) to get a very good Rancho (made by Monroe). The 5000 series is a twin-tube shock, not suited for a truck really.
With the Bilsteins, is there anyway of not getting the ugly yellow and blue shocks?
Forgot to mention my truck is 4x4.
Pretty much my issue with most shocks. I like black shocks not all sorts of colors that stick out like a sore thumb. Seems shock companies lack common sense in the color dept.
