Sponsored by: Real Truck
which transmission fluid
Old Jan 14, 2009 | 07:07 AM
British Bulldog's Avatar
British Bulldog
Hi there,
can anyone tell me the correct auto transmission fluid to use on a 2002 F350 4X4 dually. I know its is mercon, but as I live in the United Kingdom we dont have a brand called Mercon. If possable could someone tell me the SAE spec of the correct auto transmission fluid. also the correct spec for the transfer box.
I would also like to take the time to thank everyone for there help they have gave me in the past when I have posted problems.
Thanks guys.....Cheers
Old Jan 14, 2009 | 08:52 AM
CruiserClass's Avatar
CruiserClass
Mercon isn't a brand like Gulf or Amsoil, its a standard. Different people may manufacture it, but it has to conform to certain standards to be labeled "Mercon" and there are other incompatible standards, such as Dexron, Type F, ATF+4, etc.
Have you checked with your Ford dealer? Ford/Mazda dealers should carry it if your local parts house doesn't. I know Gulf makes and markets Mercon in other parts of Europe, though, so I'd be surprised if it wasn't in the UK.
Old Jan 14, 2009 | 09:04 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Come on over to the dark side!!! LOL!!! Actually, the 7.3 PSD forum is where you really want to be lurking for questions like this. The 4R100 behind the diesel is different from the one behind the gasser engines.
7.3 PSD forum
What auto parts stores do you have in the U.K.? If you can tell us that, we might be able to poke around their website and give you a recommendation.
Also, how many miles are on the tranny? Ever rebuilt? Any upgrades to the tranny, like an improved valve body, etc.? Thanks mate! Cheers!
EDIT - you might ask the moderators to move this thread to the aforementioned 7.3 PSD forum. You'll get a more focused response. To do that click on the red outlined triangle in the upper right corner of a post and you'll go to a screen where you can "report" your thread. Just ask that it be moved.
Old Jan 14, 2009 | 09:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
You can use any fluid compatible with Mercon or Mercon V. Ford issued a TSB last year that stated any transmission requiring Mercon can now be serviced with Mercon V, and that they would be discontinuing the Mercon fluid in favor of Mercon V.
You will find many brands of fluid at your local auto parts store that say they meet the Mercon or Mercon V standard. Any of those will work fine.
Old Jan 14, 2009 | 09:57 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Originally Posted by British Bulldog
Hi there,
Mercon has been replaced by Mercon V. Mercon V is to be used in the transmission, power steering and transfer case. The spec you are looking for is not a SAE spec but a Ford spec. Any trans fluid that meets Ford spec WSS-M2C202-B will work. Ford dealers in the UK sell it under the product name of E-M5 (Stock Number 8000045). There are probably other major name brands that meet the spec also, you just have to look for it on the bottle.
Halfords carries it under thier own brand name...
Halfords Ford Automatic Transmission Fluid M2C202B 1L from Halfords Price £9.99
Lattitude Adjuster
Oct 10, 2014 07:44 PM
AmmoDawg
Jan 8, 2013 09:26 AM
bobcity
Oil & Lubrication
Apr 20, 2005 08:38 PM
Nightrain
1983 - 2012 Ranger & B-Series
Jul 26, 2004 07:31 AM
ruby2
Oil & Lubrication
Mar 14, 2003 09:16 PM
