another trailer wiring question
Old Jan 13, 2009 | 09:43 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
I finally got them to come on after changing my fuses but now I have turn signals and tail lights but when i push on the brakes the lights go out and when i let off they come back on wtf??? any ideas
Old Jan 13, 2009 | 10:06 PM
rbaker6336's Avatar
rbaker6336
sounds like a ground problem
Old Jan 14, 2009 | 07:09 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree with Ray on the ground problem.
Old Jan 14, 2009 | 09:30 AM
huntke's Avatar
huntke
/\ /\ /\ /\ /\ ....ditto they can do some funny things
Old Jan 14, 2009 | 09:37 AM
superduty4x4's Avatar
superduty4x4
Another vote for ground problem, but to clarify- are the lights being weird on the trailer or the truck?
Old Jan 14, 2009 | 11:12 AM
SUPERDUTY OUTLAW
Just being weird on the trailer the ones on the truck work fine.
Old Jan 14, 2009 | 11:14 AM
just another truck's Avatar
just another truck
Then absolutly ground problem on the trailer..
Old Jan 14, 2009 | 11:23 AM
clintbonnie's Avatar
clintbonnie
I also agree.. a ground wire problem.. check the ground wire to trailer from the truck.... or run a temp ground to verify the problem..
Old Jan 14, 2009 | 11:24 AM
SUPERDUTY OUTLAW
What is the best way/ how did you run a really good ground?
Also have you heard that if you hook it to the truck it will ground it better i have been doint all my testing without it hooked up.
Old Jan 14, 2009 | 11:25 AM
rbaker6336's Avatar
rbaker6336
jumper cables work good
you should have a white wire in you pigtail that hooks to the trailer frame,a good place to start then check each light
Old Jan 14, 2009 | 11:40 AM
just another truck
Make sure the truck side is connected to ground as well. As far as I know.. the stock wiring always is.. but I have seen a couple of trailer joints forget that part..
abyars111
Nov 12, 2012 09:18 AM
boblewis
Mar 2, 2012 07:58 PM
oldfordisbetter
Jan 6, 2011 08:29 PM
conchstew
Nov 3, 2007 09:13 PM
