1965 f100 problem
Old Jan 13, 2009 | 09:14 PM
Broke_Okie's Avatar
Broke_Okie
1965 f100 problem
A friend has a 1965 swb f100 2wd truck. Recently both right and left turn signals and both brake lights stopped working. He has all of the running lights working. No fuses are bad . Wiring is in tact. What could be causing this?
Old Jan 13, 2009 | 09:32 PM
72bronc's Avatar
72bronc
check the signal light switch happened to my 66 I believe the brake lights run through the switch
Old Jan 13, 2009 | 09:45 PM
Broke_Okie's Avatar
Broke_Okie
Thanks I will check it out.
Old Jan 13, 2009 | 09:48 PM
Bill W's Avatar
Bill W
also check under the steering wheel, the power wire for the brakes runs through the indicator switch, mine was replaced at some point and the PO did a bad job with conections. Good luck
Old Jan 14, 2009 | 05:57 AM
jowilker's Avatar
jowilker
Normally I suggest starting at the rear of the truck. The turn signals and brake lights share the same bulb filiment. Since both sides stopped working at the same time, I agree with the others that the issue is likely in the cab.
An ice pick type circuit tester will work well diagnosing the problem.
John
Old Jan 14, 2009 | 01:53 PM
Broke_Okie's Avatar
Broke_Okie
Thanks. I tested the brake switch by disconnecting the switch and used a wire jumper w/ ignition on and off and no brake lights at all. I did a visual inspection and found no visible problems. Next I will look at the turn signal switch. Is there a way to test it other than just replacing it?
Old Jan 14, 2009 | 02:06 PM
72bronc's Avatar
72bronc
no lights
Pull your steering wheel off. I'm not sure if it was just mine, but there was a screw through the switch. I tightened the screw and it mad contact and all is fine. there may be a contact problem in the switch, but you'll have to pull the wheel off.
Old Jan 14, 2009 | 02:14 PM
BikerDude's Avatar
BikerDude
Check the firewall pass through connector. I had a brake light problem and it turned out that most of the pin to cup connectors were corroded so badly that I was suprised anything worked.
