odd cooling symptons
Old Jun 24, 2003 | 03:54 AM
dustinleavitt2000's Avatar
dustinleavitt2000
Question odd cooling symptons
ok this is the problem i have a fresh built engine with a new radiator and the old water pump. when i drive the car water will leak around the radiator cap (new cap) it doesnt explode and just empty like during a boil over it just intermittently released coolant. why? also when I shut it off you can hear odd sounds coming from the block and radiator.
Old Jun 24, 2003 | 04:15 AM
GT40man's Avatar
GT40man
head gasket on backwards?
Old Jun 24, 2003 | 09:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
Radiator too full? Fill to within 1" or 1-1/2" from top.
Old Jun 24, 2003 | 01:24 PM
dustinleavitt2000
it spews until the radiator is like half full and it fills up the plastic resevoir
Old Jun 24, 2003 | 01:26 PM
dustinleavitt2000
its a 16 pound cap is this enough? The return line stays pressurized for like 20 minutes after the engine is off.
Old Jun 24, 2003 | 02:58 PM
dustinleavitt2000
whats causing this please help me I need to move the car today if at all possible it needs to move 50 miles. is 16 pounds enough for the cap? could there just be air in the system?
Old Jun 24, 2003 | 04:20 PM
cartwright's Avatar
cartwright
Sounds like combustion gasses are getting in the water jackets, meaning you have a head gasket leak or cracked head. Im in the middle of rebuilding an engine that had the same problem. Get a combustion leak tester from NAPA and check it. If this is the case no radiator cap will solve the problem.
Old Jun 24, 2003 | 07:19 PM
dustinleavitt2000
hmm is that like a compression tester? I did pull one of the heads after the run in due to a stuck valve and i re used the gasket because it looked fine is this the problem?
Old Jun 24, 2003 | 07:20 PM
dustinleavitt2000
and if it was the gaskets wouldnt the system make noise when the car is on? could this pressure in the system be caused by heat or a bad water pump or thermostat?
Old Jun 24, 2003 | 07:38 PM
bubbaf250's Avatar
bubbaf250
dustin,
You can't re-use head gaskets. That's your problem.
Spec for most M-block radiator caps I've seen is 13 psi.
Old Jun 24, 2003 | 07:42 PM
dustinleavitt2000
the car only ran for 20 minutes with them on i figured i was ok, how can I be sure this is the problem before i remove the heads for another time?
also while were here i have a sp2p manifold i heard this isnt enough of a manifold would it be in my best interest to purchase a used performer or street master or something else off ebay while i am at it? because right now the car seems to have power at higher rpms but it cant even spin the tires. and how about these roller fulcrum rocker conversion things that crane makes should i get them while im at it?
Old Jun 24, 2003 | 08:30 PM
Coondawg's Avatar
Coondawg
Head gaskets are one time use only. They can't be re-used. It sounds to me like you have compression in the coolant.
If you want rollers, look at the roller rockers Ford Racing has. They have some that are made to fit the pedestal mounts on 351C, M, 400, 429, 460. You may have to use taller valve covers.
Old Jun 26, 2003 | 12:38 AM
c_rossman's Avatar
c_rossman
A guy could pressurize the cooling system. If it doesnt hold pressure for more than a few minutes, then you have issues
Old Jun 26, 2003 | 12:57 AM
dustinleavitt2000
now that ive had time to think about it, during the break in (before i reused the head gasket) it had this same problem. it would spew small amounts of coolant intermitantly, as a matter of fact i was worried about my engine and I pulled the cap off )) iknow STUPID me, my back was burned a little from the geyser lol. does this mean that my problem lies else where?
Old Jun 26, 2003 | 02:11 PM
Big Orn's Avatar
Big Orn
Have you checked the thermostat?
On the head gasket - once crushed always crushed - no matter if you run the engine or not.
Got Water in the Oil - or - Oil in Water?
