Bronco II Ford Bronco II
No Park
Old Jan 13, 2009 | 02:41 PM
wtroger's Avatar
wtroger
No Park
I posted this first in the Tranny section wiht no answers. Though maybe I might get more response here.
1988 Bronco II v6 automatic park doesn't work. just like going into neutral. Tranny shifts and drives fine. So the question is does this require a complete teardown to fix or is there some other linkage issue that could cause this.
Old Jan 13, 2009 | 07:43 PM
Army_Dave's Avatar
Army_Dave
could it possibly be the parking pin/lug is sheered off?
Old Jan 13, 2009 | 09:56 PM
tommyleea's Avatar
tommyleea
I would disconnect the linkage at the tranny, and run it thru the gears to see if it is the tranny or the linkage.
Old Jan 14, 2009 | 03:06 AM
kernel-panic's Avatar
kernel-panic
Could be a linkage / gear selector / gear selector shaft issue with adjustments or bent things - or, you could have a broken park sprag in the transmission, which unfortunately I am unsure if the A4LD's parking sprag can be replaced without a rebuild. I agree with tommyleea, I would carefully separate the linkage from the transmission and check to ensure that it is either a linkage problem or a transmission problem.
trappnman
1983 - 2012 Ranger & B-Series
16
Jun 21, 2013 03:24 PM
STROKER350
Dec 4, 2012 08:39 PM
twisted
1978 - 1996 Big Bronco
31
May 1, 2005 06:06 PM
rogue69
May 18, 2003 08:16 PM
goalie
Nov 18, 2002 11:55 AM
