Went from no muffler to glasspack with disapointing results
Old 09-23-2002, 08:36 AM
seebeew's Avatar
seebeew
seebeew is offline
My setup used to be: Inline 6, stock cat, 2.5 inch pipe exiting before the rigth rear tire.
Current setup: Inline 6, stock cat, cherry bomb.
Results: Exhaust sound is alot quieter. The tone did not change on bit.
Expected: I figured that the glasspack would make the tone a little lower. And maybe make it sound like more like a truck than a farm tractor.
Oh well...
Listen to exhaust sound clips before you buy your next exhaust system!!! Check out:
http://www.exhaustsoundclips.com
EPA Info on Mufflers and Cats. Compare muffler CFM output!!!
Old 09-25-2002, 12:54 AM
85351ho's Avatar
85351ho
85351ho is offline
if it has two catty's on it then i would leave the muffler off...i think they quiet it down enough. Plus they restrict the exhaust enough as it is.
Old 09-30-2002, 12:15 PM
seebeew's Avatar
seebeew
seebeew is offline
I have one stinkin cat... I wonder if it is plugged up. Does anyone know how to tell when your cat is bad?
Old 10-01-2002, 10:16 PM
JSS's Avatar
JSS
JSS is offline
seebeew:
I think if your mileage starts dropping suddenly and when you downshift and don't gain any speed and almost seems like you're slowing down is a good sign! For example, up until a year ago I was able to make it make this one large hill on the interstate on the way to work in 5th at 70 mph and was getting about 215 miles per tank. In the past 1/2 year, I was lucky to get up the same hill in 4th at 65 mph tops and getting only 190 miles per tank. 2 weeks ago I replaced the old cat with a new high flow cat and performance is just like a new truck, except with a lot throatier and rumbly sound. When the old, stock cat was held up to a bright light you couldn't see the light. By the way, that's a pretty good, informative website you got!
Old 10-02-2002, 01:14 AM
fordtruckin's Avatar
fordtruckin
fordtruckin is offline
Fordboy2011
2009 - 2014 F150
11-27-2016 12:18 PM
Spoonman75
08-24-2015 09:03 PM
choate
06-19-2014 12:48 PM
1990inline6
13
02-26-2014 09:01 PM
octaneforce
09-16-2013 08:42 PM
Quick Reply: Went from no muffler to glasspack with disapointing results
