I could use a second opinion on whats wrong with it tj, Its at diesel peformance in GR the only thing i cant stand about them is they are so damn expensive
#2 cyl is bad no compression and probally hole in piston
Bummer! The only other things it could be would be valve issues but I would assume they are competent enough to run a Leak down test. Ask them if they have. If they give you a blank stare and have no idea what you are talking about get your truck out of there ASAP!
