trans crossmember help
Old Jan 12, 2009 | 07:08 AM
Dalton James's Avatar
Dalton James
I need some help. I bought a 1994 F-250 4x4, 5spd, 351cid, dana 50 TTB, after lifting the truck 4" my trans crossmember is not allowing my front driveshaft to drop far enough the connect to the front axle!! I posted this Im thinking the driveshaft is the wrong one for the truck. Or the crossmember is wrong. Maybe someone with pics or part#s can help me figure this out.
Old Jan 12, 2009 | 07:31 PM
Ford_Six's Avatar
Ford_Six
I did a 6" lift and SAS on an 84 F250, and had to modify the crossmember. I cut a section out, and made a piece to go up and over the driveshaft, welded it all together, and it was fine for the rest of the truck's life.
