Exhaust ?'s
Old Jan 11, 2009 | 08:54 PM
mblanken881's Avatar
mblanken881
Exhaust ?'s
I am looking into getting a new exhaust system for my 99 F250. What is the best system for price and quality? I want a 4" turbo back system. Will these systems include the up-pipes or will I have to buy those separately? I need new up-pipes as they are leaking. Thanks, Mike.
Old Jan 11, 2009 | 08:56 PM
Adam0331's Avatar
Adam0331
MBRP is a good one, I haven't any set ups with the up-pipes. They are always separate.
Old Jan 11, 2009 | 08:59 PM
mblanken881
Is this a good system?:
eBay Motors: MBRP 99-03 FORD F250 / F350 7.3L DIESEL EXHAUST (item 380089897440 end time Jan-12-09 16:43:26 PST)
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is the exhaust I have and works great. click here
Old Jan 11, 2009 | 09:02 PM
F350-6's Avatar
F350-6
If the up pipes are leaking and you want a cure-all fix, look into a set of bellowed up-pipes. You can get them from your local IH dealer, or ITP sells them on their website. Here's a write up of the install Welcome to Pocket's International UP-Pipe Replacement Web Page
If you don't want to do the bellowed up pipes, a set of donut gaskets for a small block will work to seal the pipes.
Old Jan 11, 2009 | 09:04 PM
Adam0331's Avatar
Adam0331
You may want stainless, and also I think the stainless kits come with a tip. That kit is aluminized and doesn't come with a tip as far as I know. Rick's is a good kit.
mblanken881
I hear alot about Banks from my Duramax buddies. But not alot about it on FTE. What do you guys think about Banks?
Old Jan 11, 2009 | 09:06 PM
Adam0331's Avatar
Adam0331
Overpriced from what I have noticed. I think everyone on here will agree with that. There aren't very many fans of Banks stuff on here.
Old Jan 11, 2009 | 09:09 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Old Jan 11, 2009 | 09:11 PM
Adam0331's Avatar
Adam0331
That seems to be the general consensus. HAH! I think Kris tried giving me that sticker, too.
Old Jan 11, 2009 | 09:15 PM
mblanken881
Originally Posted by strokin_it7.3
Great sticker!! HAHA!!
Old Jan 11, 2009 | 09:23 PM
PowerstrokeJunkie
Yeah its gone now, too bad
Old Jan 11, 2009 | 09:52 PM
DieselBeast01's Avatar
DieselBeast01
yep....Everything I have seen from Banks is way overpriced. I would go with a MBRP or MKO
Old Jan 11, 2009 | 09:56 PM
mblanken881
I think I am going to order the MBRP tomorrow. Is this kit something that can be installed in the driveway? If I back the truck into the garage I can only get it in to the cab because its too tall. I'm in Omaha, NE and it's suppose to be quite cold the end of next week. If I drive to Des Moines, IA (2 hrs) I can use my buddies shop to do the job. Would you freeze your butt off in Omaha and do the job by yourself or drive to Des Moines and do the job in a warm shop with a buddies help?
Old Jan 11, 2009 | 10:10 PM
mblanken881
If I was to simply replace the donuts on the up-pipes and lube with antisieze, how long am I looking at until they would need replaced again? I would like to do the exhaust system now and the up-pipes later, say in a year or two. Also, how would I go about replacing the donuts? Would I just remove the turbo and be able to access the donuts from there?
Thanks, Mike.
