newbe with head problem. - VA
Old Jan 11, 2009 | 05:56 PM
tww62's Avatar
tww62
Post newbe with head problem. - VA
Hi all, I'm a from Boones Mill Va. I'm new to this thread thing. I've owned Ford trucks most of my life.I recently purchased an '02 F250 with a v10 engine. (I get 1mpg per cylinder). After about a week the spark plug closest to the driver(me) blow out while I was driver home. Apparently this is why it was sold?! I'm now in the process of putting this mess back together. Any suggestions on removing the old head gasket without damaging aluminum head? also how clean does it have to be?
Ok I'm done.
Old Jan 11, 2009 | 06:28 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE!
I can tell you where to post that question - right here in the V10 forum:
https://www.ford-trucks.com/forums/forum49/
They'll get you squared away in no time.
You might also want to visit the Virginia chapter of FTE and post your intro in there:
https://www.ford-trucks.com/forums/forum147/
Thanks for signing up, and good luck!
Old Jan 15, 2009 | 11:21 PM
billcarr's Avatar
billcarr
As far as clean you probably need to get it smooth to touch so as not to blow another gasket. Scraping is sure out. What does Ford or a trusted mechanic recommend?
Old Jan 16, 2009 | 02:55 AM
Sparky83's Avatar
Sparky83
welcome to the site mate... sorry to hear about the plug blowing out but it seems to be a common occurrence on these v10 heads from what ive read in my short time here...
as for getting the aluminum head cleaned.. not sure mate... my only guess would be some parts cleaner... but ive never worked with aluminum heads yet.. my only experience is with cast iron heads...
Gruetzmacher
New Member Introductions
Nov 21, 2006 11:58 PM
