6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 Job Numbers and Changes
Old May 6, 2010 | 08:21 PM
sdetweil's Avatar
sdetweil
Originally Posted by Glockem45
So Sam, essentially since this one is a 2010 model, then it is the Job1 version of the 2010 models?
correct
Sam
Old Aug 25, 2010 | 11:49 AM
rbunk's Avatar
rbunk
build date
hey guys I looked on my door frame and the only date is 8/7 is this the build date?
Old Aug 25, 2010 | 01:00 PM
sdetweil's Avatar
sdetweil
so u have a 2008, that was built 08/07. so probably Job 1. the tech sticky at the top should show the job num ranges for 08's
or maybe a job 2 according this link in the tech folder
https://www.ford-trucks.com/forums/8...ml#post6393602
Sam
Old Aug 25, 2010 | 02:34 PM
R-T0r21on's Avatar
R-T0r21on
Sam
I think job#2 trucks began in June 07.
Old Aug 26, 2010 | 10:42 AM
rbunk's Avatar
rbunk
well i guess I have job 2 then because I have 4 in air dam and tire pressure montering system.
08 sd cc 156 wb got it with 25,000 mi on it and traded a 2003 6.0 in for it. This is way better trk and engine, this being my third SD.
Old Aug 26, 2010 | 10:50 AM
pog23's Avatar
pog23
I have Job 2 08/07 but it doesn't have TPMS. Maybe it wasn't standard for the HD edition? How would I find out if I have Rapid Heat supplement?
Old Aug 27, 2010 | 11:58 AM
rbunk's Avatar
rbunk
not sure about rapid heat I know mine has it and also the owners manual tells u how to use it the other thing is wait till winter
Old Aug 27, 2010 | 01:26 PM
Rudiak's Avatar
Rudiak
How can one tell if they have tpms?
Old Aug 27, 2010 | 01:33 PM
R-T0r21on's Avatar
R-T0r21on
I don't think TPMS was even an option on the job #1 trucks. At least I don't remember it being an option when I ordered my truck. I believe it became standard/mandatory in 2009. Same as traction control..... Someone correct me if I'm F'd up.
Old Aug 27, 2010 | 02:32 PM
senix's Avatar
senix
my job 3 has the tpms...I thought that after jan 08 it was suppose to be mandatory.
Mine was born Mar 08.
Old Sep 1, 2010 | 01:04 AM
ducky1402's Avatar
ducky1402
ok so my door says 7/07 so guessing that is job 1.... Any big problems with job 1 trucks? I have over 20k on it and seems well.
Old Sep 1, 2010 | 04:58 AM
senix's Avatar
senix
Job 1 trucks were the most prone to radiator leaks at the seams, usually down towards the bottom against the frame is where you would see them.
Old Sep 1, 2010 | 10:17 AM
  #28
ducky1402's Avatar
ducky1402
good to know I will keep an eye on it thank you
Old Sep 1, 2010 | 01:08 PM
  #29
kylebryan's Avatar
kylebryan
mines a job 1 build date 7/07. and i have had the radiator leak problem. Other than that no issues.
Old Mar 30, 2012 | 10:39 PM
  #30
ATX F250's Avatar
ATX F250
Originally Posted by caprang
JOB 3 ORDER GUIDE UPDATES – Effective on all
vehicles built on or after Job 3 (01/02/08 – Subject to
change)
• The 60th Anniversary Edition (17A) is now available on XLT
SuperCab and Crew Cabs. It includes a two tone exterior paint
combination in Black with Dark Shadow Grey lower accent or
Dark Shadow Grey with Black lower accent, Chrome billet-style
grille, 5" chrome running boards, chrome exhaust tip, chrome
tow hooks and chrome pickup bed tie-down hooks, chrome
mirror caps, body color front and rear bumpers, accent color
wheel lip moldings, and unqiue 60th Anniversary Edition wheel
ornaments, box decals and badges. The Medium Stone interior
includes Sport Cloth Captain's Chairs, a leather wrapped
steering wheel, unique instrument cluster appliqué, 60th
Anniversary center console badge, serialization plate, and
more. Please see the Packaged Options page for a full list of
package contents.
• There have been changes made to the standard and optional
axles in the Axle Availability chart. Please review the Axle
Availability chart for all axle availability changes.
• The Front License Plate Bracket is no longer standard. The
Front License (153) is available as an option on all trims and is
forced in states where required.
• The Rapid-Heat Supplemental Cab Heater (41A) is now
available with manual transmission.
• The PowerScope™ Trailer Tow Mirrors (54F) are now available
on XLT Regular Cab (require the Advanced Security Group).
• A Winter Front Grille Cover is now standard and only available
with the 6.4L diesel engine in the following states: AK, CO, ID,
IA, ME, MI, MN, MT, NH, NY, ND, SD, VT, WI, WY.
LATEST ORDER GUIDE UPDATES
• The 3.73 Limited Slip Axle (X3L) is now available on F-350
SRW Pickups with the 6.4L diesel engine, automatic
transmission and 17" or 18" wheels.
So I am guessing that my truck is a Job 3 since on my window sticker the front license plate bracket is listed as an option?
