polished fender bolts, what to do?
1st of all, cool truck...I particuarily like the tubs. Not to get off topic but did you make them or adapt them for something else?
Maybe I'm off-beat here, but I though their was a tool to punch square holes in sheet metal. Something similar to the tools used to re-skin doors, only it's an actual punch. I think their called a "Sheet Metal Punch". They do either round or square holes depending on the ones you buy. Just an idea...hopefully...they do a better job or punching holes...then I do typing
Got the tubs cheap from www.suicidedoors.com. they custom made them for me (cut down of their standard size).. see my gallery for pics..
Sam
There's a reason that the bolts have a square shoulder...that's what keeps the bolt from turning when the nut is tightened. Remove the shoulder or enlarge the hole in the bed and now you have no way of holding the bolt secure when you tighten the nut. Greenlee or other manufacturers make nice square punches just for this job. Punch the holes square, any damage to the paint should be hidden by the head of the bolt.
I'll have to check that out..but I'm not very excited about taking a punch to these bedsides..
sam
I would not try to remove the square shoulder if it was not stainless which I understood that they are in this case. However, that said getting a square punch is the best approach.
on
1 Post
Square peg-round hole.....too bad you weren't aware of that before paint....Other than milling the bolts, which as was previously stated, you loose the ability to fully torque the nuts and the bolt will just turn.
Another option, which will also result in a little paint damage, would be to use a triangular file to create the square hole required for these fasteners. You could then touch up the paint, which would be hidden behind the bolt head and the fender.
The quickest, simplest, no-risk solution is button-heads. They won't require doing anything to risk damage to your paint and the allen-wrench socket is hardly noticable. The only downside is that the one time you tighten them, you'll likely need another pair of hands to hold the allen wrench. You'll likely never touch them again. Some button-heads are made to accept a chrome cover that snaps over the installed bolthead.
Here's an alternative: grind off the corners on the bolt heads, and grind square the last 1/4" of the threaded end, enough to get a wrench on it (or cut a slot with a Dremel and a thin disc). Then you can keep the bolt from turning from the inside of the fenderwell.
Boy Sam did I ever read your post wrong. Sorry!
But Charlie's right though about the collar keeping the bolt from turning when tightened. You could probably file some corners in the round holes in the fender with a triangular file fairly quickly. And that way it's wont hurt your paint job.
Good luck,
Julie
Good luck,
Julie
On my first '56 I ever had I made the bedsides and used a triangle file to "square" the drilled round holes. It was easy. I would recommend filing from the finished inside of the bedside and PUSH the file only. If you drag the file then the paint tends to come off.
If you round off the square part of the bolts; you won't be able to torque the nut on correctly. Word of caution: When you do get around to torquing those bolts/nuts be careful to not over-torque because the head of the bolt will pull the bedside in and put a nice 4" dia dent in your bedside!
I'm apparently missing something here. I went back and re-read your initial post, looking for some sentence stating that you MUST have this job done by today 2pm for some reason. Is the truck 99.9% complete and this is all you lack, Sam? Why not just have MF next day air you the right fasteners? Or visit your local Fastener supply house? I don't understand why, with a truck as nice as that, you would even consider doing otherwise. Again, I may have misconstrued the sitchamuashun.
#28
1. the shoulder is there for a specific purpose, like the dimples on the stock bolts
(I have the right part)
2. I should adjust the bedside to accommodate the bolt shoulder
(should have done this before paint, planning, planning, planning)
3. it is possible to do without severe paint damage
(others have, so I 'should' be able to)
4. I can do this with a metal file, and not require the brute force of a greenlee style pinch punch.
5. an alternative to 2/3/4 is to use a different fastener (button head), which presents it own problems (relative to the desired results)
haste makes waste...
sam
#29
but I am running out of easy things to do.. and will have to tackle that soon.
(and the gauges problem.. why do I pick designs that have limited alternative choices.. don't answer that!)
Sam
#30
