E3 Sparkplugs
Old Jan 11, 2009 | 01:03 AM
displacement4me's Avatar
displacement4me
E3 Sparkplugs
Has anyone used them? They are somewhat new and kind of hard to find for me actually.
Horsepower TV did a simple dyno swap and gained 5.5 horsepower and burnt less fuel.
The dyno comparison was against what looks like Bosch
http://www.e3sparkplugs.com/mediacenter
and its the second video, with the yellow picture preview.
Old Jan 11, 2009 | 02:25 AM
hittman1422's Avatar
hittman1422
page cannot be found buddy...
i use the bosch platnum plugs and they appear to burn gas inside my engine... other than that they're great!
Old Jan 11, 2009 | 02:42 AM
displacement4me
Spark plugs for automobiles small engines and sports craft ********
Old Jan 11, 2009 | 04:22 AM
Prozon's Avatar
Prozon
I havn't used them personally but i've been considering getting some. Kind of spendy for a plug though. :P
Old Jan 11, 2009 | 06:52 AM
pfogle's Avatar
pfogle
The only plug to run in an older Ford is a motorcraft. The bosh platinums tend to create a rough idle, and the E3 plugs are snake oil. What else did they do on HP to make that car gain? Cold air intake, new fuel filter?
Old Jan 11, 2009 | 01:12 PM
displacement4me
1. I was considering these for my well built 460 w/ aluminum heads, etc...
2. It was a engine dyno with "Plug A", a cool down and swap to E3 plugs, and a second dyno. The plugs produce the gain.
Old Jan 11, 2009 | 01:39 PM
boggerted's Avatar
boggerted
I've run these in pulling tractors because normally I would have to index the plug (on a flathead, you make a mark on the outside of the plug that allows you to point the plug gap towards the piston for more power). However, I got the same power with the e3 without the trouble of indexing the plugs, and Ive been running them for a very long time with no loss of performance.
Old Jan 12, 2009 | 03:46 PM
focusdriverlx20's Avatar
focusdriverlx20
new "magic plug" yay...
honestly, a plug is a plug is a plug. the 5.5HP gain is well within the "noise" of a dyno, and honestly that gain is prob because the bosch were used plugs that were done. try it yourself, run a dyno on the plugs you run now, swap to new plugs, and see the HP "gain" from your new plugs. its all marketing, and they are nothing more then snake oil. if you believe that these work better then any other plug, then i have another system that will save you fuel...
https://www.asseenontv.com/offers_on..._ood_ontv.html
Old Jan 12, 2009 | 09:57 PM
86F150302's Avatar
86F150302
I just changed my plugs and it had the bosch platnuim 2 plugs in it. Switched to NGK V powers and made a huge difference in idle and throttle response.
Old Feb 11, 2009 | 08:39 PM
outlaw24's Avatar
outlaw24
well it is up to the person that is open to trying new things i gus and that is me and i put sume in my 351w and i ame seeing a good change in the performanc but i have to go off the feal of the truck i dont have acses to a dino and my speedo dont work but i do like them
Old Feb 11, 2009 | 09:38 PM
bashby's Avatar
bashby
Bosch plat's are worthless IMO, I have had several customers over the last few years that did their own tune up and got the Bosch platinums as reccomended by the local Autozone counter guru. Put in some autolites and problem solved. Motorcrafts are good in fords, champ's in dodge, ngk in japs, and Bosch in german cars only. Autoltes seem universal in my experience
Old Feb 11, 2009 | 11:49 PM
bmuhlbach's Avatar
bmuhlbach
I bought them (MADE IN CHINA) put them in my 06 Focus for the mileage increase I to watched Hot rod t.v.I got worse mileage I want from 31 to 29 and Fofo seems to idle with vibration.They may do better in older stuff thou.
Old Feb 12, 2009 | 05:39 AM
srercrcr's Avatar
srercrcr
It's endless....promote the new miracle spark plug. Just put in OEM plugs and get on with it. I'm hearing some of these plugs don't last as long, center wears away.
Old Feb 12, 2009 | 10:47 AM
bmuhlbach's Avatar
bmuhlbach
remember the split fire that also was the great plug.
Old Feb 12, 2009 | 11:32 AM
displacement4me
The engine isn't quite OEM anymore, I went with them anyways at a bit colder range.
