E3 Sparkplugs
Old Feb 12, 2009 | 03:25 PM
focusdriverlx20's Avatar
focusdriverlx20
Originally Posted by bmuhlbach
I bought them (MADE IN CHINA) put them in my 06 Focus for the mileage increase I to watched Hot rod t.v.I got worse mileage I want from 31 to 29 and Fofo seems to idle with vibration.They may do better in older stuff thou.
honestly, throw some autolite 104s in there, and you will be good. best plug for that car by far.
Old Feb 12, 2009 | 11:28 PM
bmuhlbach's Avatar
bmuhlbach
I plan to go back to autolites
Old Feb 18, 2009 | 12:00 AM
whatthencuz's Avatar
whatthencuz
so would a platinum motorcraft spark plug be better than a copper one? right now im using motorcrafts sp-450's in my 82' with a 302 and they run good but will platinum plugs be even better?
Old Feb 18, 2009 | 06:51 AM
Mausinn's Avatar
Mausinn
Platinum is supposed to be a better conductor. The only thing they seems to conduct better is your money out of your wallet. JMHO.
Old Feb 18, 2009 | 07:13 AM
Lead Head's Avatar
Lead Head
It is not that platinum conducts better, platinum is stronger. Most modern ignition system create enough voltage to cause the electrodes on normal plugs to erode. Platinum is far more resistant to the erosion from the actually spark itself
Old Feb 18, 2009 | 11:42 AM
bashby's Avatar
bashby
Ive heard that copper plugs Make a hotter spark than platinums. Dont know if its true or not
Old Feb 18, 2009 | 11:52 AM
bashby's Avatar
bashby
Here's a snip of something I googled up:
In a racing environment, there are generally no emissions standards and an excessive amount of fuel present. This environment can cause spark blowout if you are not using the appropriate setup. Platinum spark plugs are not recommended in this situation because, more often than not, spark blowout will occur due to the fact that the tip surfaces of a platinum spark plug is not large enough to make a good conductor in a rich, super high compression environment. Standard type spark plugs provide plenty of surface area for the spark to conduct under such conditions. Therefore a conventional non-resistor spark plug is recommended because it has a larger surface area that will allow the spark to occur.
Old Feb 19, 2009 | 07:34 PM
forum155pl's Avatar
forum155pl
plugs are plugs. i run motorcraft TR6's in my 557 HP turbo mustang, if i remember right they were a little over a 2 bucks each. if you want better spark, upgrade the ignition
Bertha1
43
Sep 2, 2019 03:26 PM
skidmarks82
1997 - 2003 F150
18
May 24, 2009 07:38 AM
bazzman1953
1983 - 2012 Ranger & B-Series
22
Oct 22, 2008 11:08 PM
builtfordtough13
17
Jul 2, 2008 01:46 AM
